Intel i7 12th gen on a Medion laptop. I should have V3 enabled
That’s right. Though I checked here too just in case.
So, you’ll want to use this as your pacman.conf instead.
# /etc/pacman.conf
# See the pacman.conf(5) manpage for option and repository directives
# GENERAL OPTIONS
[options]
# The following paths are commented out with their default values listed.
# If you wish to use different paths, uncomment and update the paths.
#RootDir = /
#DBPath = /var/lib/pacman/
#CacheDir = /var/cache/pacman/pkg/
#LogFile = /var/log/pacman.log
#GPGDir = /etc/pacman.d/gnupg/
#HookDir = /etc/pacman.d/hooks/
HoldPkg = pacman glibc
#XferCommand = /usr/bin/curl -L -C - -f -o %o %u
#XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u
#CleanMethod = KeepInstalled
#UseDelta = 0.7
Architecture = auto
# Pacman won't upgrade packages listed in IgnorePkg and members of IgnoreGroup
#IgnorePkg =
#IgnoreGroup =
#NoUpgrade =
#NoExtract =
# Misc options
#UseSyslog
Color
ILoveCandy
#NoProgressBar
#CheckSpace
VerbosePkgLists
DisableDownloadTimeout
ParallelDownloads = 10
DownloadUser = alpm
#DisableSandbox
# By default, pacman accepts packages signed by keys that its local keyring
# trusts (see pacman-key and its man page), as well as unsigned packages.
SigLevel = Required DatabaseOptional
LocalFileSigLevel = Optional
#RemoteFileSigLevel = Required
# NOTE: You must run `pacman-key --init` before first using pacman; the local
# keyring can then be populated with the keys of all official Arch Linux
# packagers with `pacman-key --populate archlinux`.
# REPOSITORIES
# - can be defined here or included from another file
# - pacman will search repositories in the order defined here
# - local/custom mirrors can be added here or in separate files
# - repositories listed first will take precedence when packages
# have identical names, regardless of version number
# - URLs will have $repo replaced by the name of the current repo
# - URLs will have $arch replaced by the name of the architecture
# Repository entries are of the format:
# [repo-name]
# Server = ServerName
# Include = IncludePath
# The header [repo-name] is crucial - it must be present and
# uncommented to enable the repo.
# cachyos repos
[cachyos-v3]
Include = /etc/pacman.d/cachyos-v3-mirrorlist
[cachyos-core-v3]
[cachyos-extra-v3]
[cachyos]
# The testing repositories are disabled by default. To enable, uncomment the
# repo name header and Include lines. You can add preferred servers immediately
# after the header, and they will be used before the default mirrors.
#[core-testing]
[core]
#[extra-testing]
[extra]
# If you want to run 32 bit applications on your x86_64 system,
#[multilib-testing]
[multilib]
# An example of a custom package repository. See the pacman manpage for
# tips on creating your own repositories.
#[custom]
#SigLevel = Optional TrustAll
#Server = file:///home/custompkgs
It looks to be what I need. Try to overwrite with yours. My backups and my Pen-Drive are ready in the worst case ![]()
Once your CachyOS repos are enabled again(and I’m not sure but you may need to restart first), you should then be able to replace those 4 kernel packages with the native ones from cachyos-v3.
Thank you so much for your help, everything is ok again
if you run the automated script from CachyOS’s wiki, it’ll detect hardware and sort out your repo’s
This (weird unconfigured pacman.conf) is almost always the result of overwriting the local file with the pacnew.
Whether the user did this on purpose or used a (bad) tool.
This is not how we manage pacnews!
In the future take care to manually review them and merge in portions of the files as needed. Yes, manually, there is no other way.
(post deleted by author)
Exactly what I stupidly did, I used a bad tool. From now I’ll strictly use Arch or Cachy Specific way to cleanup my system
I had my own little adventure/lesson with this - every day is a school day ![]()
