CPU: Intel Core i7-13700KF (No degradation symptoms, latest microcode applied)
GPU: AMD Radeon RX 9070 XT
DE/WM: KDE Plasma (Wayland)
The Issue: I am experiencing random hard system freezes. The system locks up completely — I cannot switch to a TTY, and Magic SysRq (REISUB) is completely unresponsive, forcing me to do a hard reset via the power button.
This happens randomly during regular desktop usage (not just during heavy gaming).
steam[8796]: assert_20260428083319_49.dmp[21947]: Finished uploading minidump (out-of-process): success = no
steam[8796]: assert_20260428083319_49.dmp[21947]: error: Failure when receiving data from the peer
steam[8796]: assert_20260428083319_49.dmp[21947]: file ‘’/tmp/dumps/assert_20260428083319_49.dmp’‘, upload no: ‘‘Failure when receiving data from the peer’’
assert_20260428083800_52.dmp[22006]: Finished uploading minidump (out-of-process): success = no
at-spi2-registryd[1981]: Re-enabling app with pid 3320
assert_20260428083800_52.dmp[22006]: error: Failure when receiving data from the peer
assert_20260428083800_52.dmp[22006]: file ‘’/tmp/dumps/assert_20260428083800_52.dmp’‘, upload no: ‘‘Failure when receiving data from the peer’’
assert_20260428083319_49.dmp[21947]: file ‘’/tmp/dumps/assert_20260428083319_49.dmp’', upload no: ‘‘Failure when receiving data from the peer’’
pipewire[1773]: spa.alsa: front:3p: (4 suppressed) snd_pcm_avail after recover: Обрыв канала
pipewire[1773]: spa.alsa: front:3p: (0 suppressed) snd_pcm_avail after recover: Обрыв канала
at-spi2-registryd[1981]: Re-enabling app with pid 2031
at-spi2-registryd[1981]: Re-enabling app with pid 2034
at-spi2-registryd[1981]: Re-enabling app with pid 1917
pipewire[1773]: spa.alsa: front:3p: (2 suppressed) snd_pcm_avail after recover: Обрыв канала
at-spi2-registryd[1981]: Re-enabling app with pid 2030
at-spi2-registryd[1981]: Disabling unresponsive app with pid 1917
at-spi2-registryd[1981]: Disabling unresponsive app with pid 2034
at-spi2-registryd[1981]: Disabling unresponsive app with pid 2030
at-spi2-registryd[1981]: Disabling unresponsive app with pid 2031
pipewire[1773]: spa.alsa: front:3p: (11 suppressed) snd_pcm_avail after recover: Обрыв канала
