GUI issues , which are concerning , plus system crashes
Hi there , very much injoying cashy kde now i month after arch (nice features here !) But am haveing issues that i can not solve , system updated daily , i hope its not my hardware , i had no problens in arch linux (wayland ) 1. mouse pointer disappears ( instead of solid arrow it stretches out to 2 inchs of fuzzy blurry mess of frustrateion ) 2. Gui apps like dolphin just fuzz out , plus apps blink randomly like there going to fail 3. System freezes and have to power off and reboot ( happens rarely ) There are suggestion from experienced linux users (DT ) that wayland is just not ready or is this fixable , i am staying backed up , but am concerned running this os on this my main machine ( 6 tb plus of data ) Any one have experience with this its something with grafix and display function ablibity ?? Tanx in advance for any helfp, as i say i love the os and features .
  1. That’s a Plasma 6/6.1 feature. You can disable it via Settings → Accessibility → Shake Cursor
  2. Don’t understand
  3. Provide logs
Wayland is very much ready, already has been since over a year ago, much more ready since explicit sync was merged.
F y i developers , i had no effects enabled including shake cursor, as reported the mouse cursor all but disappeared , and apps intermittently went fuzzy as well as screen glitching intermittently. And i could not solve this unusable system , i was going to do a clean reinstall , instead i just went back to installing arch problem solved .
