GRUB clearcpuid=514
hi, Is this something I should do ?
some games need this on AMD CPU
but I ve no /etc/default/grub ??
what is grub-steamos ?
which?
Then you are not using GRUB.
Hogwarts Legacy needs it
But I ve a /etc/default/grub-steamos with a classic CMD_LINE_BLA_BLA variable with a comment: needed by jupiter
So where can I put this variable ? In the kernel manager ?
It definitely does not. Maybe it was needed in the past but no need now.
I don’t know what that is or where it came from.
ok thx I ll try something else
So I’ve added the clearcpuid=514 and Hogwarts Legacy is now playing with proton hotfix (and VC redist)
Other games are ok too
So far so good
