Today I powered on my system and later switched on my Soundcore Space Q45 headset which has worked for over a month now.
After hearing the connect sound from my headphones, Gnome crashed to the login screen while the disconnect sound played.
While not being logged in the headset connected again (connect sound played) and the screen went black for a second, disconnect sound played and I was back to the login screen.
This loop repeats until I switch the headset off.
I tried my bluetooth earplugs and they worked without problems.
I don’t see anything suspicious in the journal.
Looks like I missed that in my first edit:
Jan 04 21:57:50 nerdonomicon kernel: input: soundcore Space Q45 (AVRCP) as /devices/virtual/input/input52
Jan 04 21:57:50 nerdonomicon systemd-logind[1266]: Watching system buttons on /dev/input/event11 (soundcore Space Q45 (AVRCP))
Jan 04 21:57:52 nerdonomicon gsd-media-keys[130916]: **
Jan 04 21:57:52 nerdonomicon gsd-media-keys[130916]: Gvc:ERROR:../gnome-settings-daemon/subprojects/gvc/gvc-mixer-stream.c:535:gvc_mixer_stream_get_port: code should not be reached
Jan 04 21:57:52 nerdonomicon gsd-media-keys[130916]: Bail out! Gvc:ERROR:../gnome-settings-daemon/subprojects/gvc/gvc-mixer-stream.c:535:gvc_mixer_stream_get_port: code should not be reached
Jan 04 21:57:52 nerdonomicon systemd-coredump[187396]: Process 130916 (gsd-media-keys) of user 1000 terminated abnormally with signal 6/ABRT, processing...
Jan 04 21:57:52 nerdonomicon systemd[1]: Started Process Core Dump (PID 187396/UID 0).
Jan 04 21:57:52 nerdonomicon gnome-shell[130378]: **
Jan 04 21:57:52 nerdonomicon gnome-shell[130378]: Gvc:ERROR:../gnome-shell/subprojects/gvc/gvc-mixer-stream.c:535:gvc_mixer_stream_get_port: code should not be reached
Jan 04 21:57:52 nerdonomicon gnome-shell[130378]: Bail out! Gvc:ERROR:../gnome-shell/subprojects/gvc/gvc-mixer-stream.c:535:gvc_mixer_stream_get_port: code should not be reached
Jan 04 21:57:52 nerdonomicon gnome-shell[130378]: == Stack trace for context 0x55a1982e3460 ==
Jan 04 21:57:52 nerdonomicon gnome-shell[130378]: #0 55a1983afaa8 i resource:///org/gnome/shell/ui/init.js:21 (1ddd6fe8d8d0 @ 48)
Jan 04 21:57:52 nerdonomicon systemd-coredump[187398]: Process 130378 (gnome-shell) of user 1000 terminated abnormally with signal 6/ABRT, processing...
Jan 04 21:57:52 nerdonomicon systemd[1]: Started Process Core Dump (PID 187398/UID 0).
Jan 04 21:57:52 nerdonomicon systemd-coredump[187397]: [🡕] Process 130916 (gsd-media-keys) of user 1000 dumped core.
Stack trace of thread 130916:
#1 0x00007f3fbeabc645 g_cond_wait (libglib-2.0.so.0 + 0xa3645)
#2 0x00007f3fbea40575 g_async_queue_pop_unlocked (libglib-2.0.so.0 + 0x27575)
#3 0x00007f3fbeac62f7 n/a (libglib-2.0.so.0 + 0xad2f7)
#4 0x00007f3fbeac5d69 n/a (libglib-2.0.so.0 + 0xacd69)
#5 0x00007f3fbe4a80d6 n/a (libc.so.6 + 0xa80d6)
#6 0x00007f3fbe53b05c n/a (libc.so.6 + 0x13b05c)
Stack trace of thread 131070:
#0 0x00007f3fbe4b0892 n/a (libc.so.6 + 0xb0892)
#1 0x00007f3fbe4a42d8 n/a (libc.so.6 + 0xa42d8)
#2 0x00007f3fbe52cb33 ppoll (libc.so.6 + 0x12cb33)
#3 0x00007f3fbea828a0 n/a (libglib-2.0.so.0 + 0x698a0)
#4 0x00007f3fbea82982 g_main_context_iteration (libglib-2.0.so.0 + 0x69982)
#5 0x00007f3fbea829d2 n/a (libglib-2.0.so.0 + 0x699d2)
#6 0x00007f3fbeac5d69 n/a (libglib-2.0.so.0 + 0xacd69)
#7 0x00007f3fbe4a80d6 n/a (libc.so.6 + 0xa80d6)
#8 0x00007f3fbe53b05c n/a (libc.so.6 + 0x13b05c)
Stack trace of thread 131074:
#4 0x00007f3fbea82b2f g_main_loop_run (libglib-2.0.so.0 + 0x69b2f)
#5 0x00007f3fbed238ac n/a (libgio-2.0.so.0 + 0x1258ac)
Stack trace of thread 131115:
#5 0x00007f3fbccc285e n/a (libdconfsettings.so + 0x785e)
ELF object binary architecture: AMD x86-64
Jan 04 21:57:52 nerdonomicon systemd[1]: systemd-coredump@5-3-187396_187397-0.service: Deactivated successfully.
Jan 04 21:57:52 nerdonomicon systemd[1]: systemd-coredump@5-3-187396_187397-0.service: Consumed 301ms CPU time over 335ms wall clock time, 138.9M memory peak.
Jan 04 21:57:52 nerdonomicon systemd[130000]: org.gnome.SettingsDaemon.MediaKeys.service: Main process exited, code=dumped, status=6/ABRT
Jan 04 21:57:52 nerdonomicon systemd[130000]: org.gnome.SettingsDaemon.MediaKeys.service: Failed with result 'core-dump'.
Jan 04 21:57:52 nerdonomicon systemd[130000]: org.gnome.SettingsDaemon.MediaKeys.service: Consumed 298ms CPU time over 2h 2min 35.910s wall clock time, 69.3M memory peak.
Jan 04 21:57:53 nerdonomicon systemd[130000]: org.gnome.SettingsDaemon.MediaKeys.service: Scheduled restart job, restart counter is at 1.
Jan 04 21:57:53 nerdonomicon systemd[130000]: Starting GNOME keyboard shortcuts service...
Jan 04 21:57:53 nerdonomicon systemd[130000]: Started GNOME keyboard shortcuts service.
Jan 04 21:57:53 nerdonomicon systemd[1]: Starting Hostname Service...
Jan 04 21:57:53 nerdonomicon systemd[1]: Started Hostname Service.
Jan 04 21:58:00 nerdonomicon systemd-coredump[187400]: [🡕] Process 130378 (gnome-shell) of user 1000 dumped core.
System Details Report
Report details
- Date generated: 2026-01-04 19:26:40
Hardware Information:
- Hardware Model: ASUSTeK COMPUTER INC. ROG STRIX B450-F GAMING
- Memory: 48.0 GiB
- Processor: AMD Ryzen™ 7 3700X × 16
- Graphics: NVIDIA GeForce RTX™ 3080 Ti
- Disk Capacity: 5.0 TB
Software Information:
- Firmware Version: 5801
- OS Name: CachyOS
- OS Build: (null)
- OS Type: 64-bit
- GNOME Version: 49
- Windowing System: Wayland
- Kernel Version: Linux 6.18.3-2-cachyos
