It’s based on Arch and easy to maintain.
Architecture-specific builds and just about no other reason.
To be fair - I think its the main thing Cachy offers, but then again that may be biased.
The two things that matter most to me - functionality and performance.A distant third for me is ease of use, though this has ease of use too as an added bonus.
Being Arch based it provides the latest and most complete functionality with standard packages. Then I also like the architecture-specific builds and optimizations for performance.
I should mark this as a solution, but I don’t want to take the chilis out of the sauce ![]()
It is the frist distribution, where I did not run into dependency issues.
It is the first distribution, where I could get a clue, what the heck is goimg wrong with my hard- and software.
It is the first distribution, where nearly all my audio and midi stuff runs as expected, though it has never been released for this kind of things.
It is the first distribution where I could try out things, whithout ending into reinstalling the complete system. OK. There was one exception. But it was just 1.
May I ask what other distributions you have tested before?
Performant rolling release with easy and well-supported zfs root
That’s what I want to hear ![]()
Most were Debian based. Ubuntu Studio, AV Linux, Mint. I would probably have tried out more, when not stumbling to the blog of a discuss.cachyos.org user who just told his story about switching to COS.
So I thought, I should give it a try.
I only learned about CachyOS when I read that Garuda users were using Cachy Kernel.
Cachy - what is it?
I downloaded it and was impressed.
Now I have two distributions to maintain, and my learning curve is steadily increasing.
EndeavourOS, which is where my journey to Aech began, will remain unforgettable ![]()
I had been using arch for a long time and grew tiresome of some configurations and especially nvidia related problems I was having.
I have broken and manually installed arch more times than I can remember, while it was actually fun, helpful in my learning process.
I was looking for stability in areas I still have much to learn in and also wanting to learn more on the optimization side of things.
I noticed cachy was growing in popularity, well the kernel specifically so I tried the kernel, cachy had optimized repos so looked into the distro and decided to jump ship.
The conversion was seamless, considering cachy follows arch in almost all areas.
Some time after I decided to join the discord and was welcomed into a wonderful community, many great helpers and a wealth of information from the growing user base.
I got to know some of the team and was impressed at the thought and care that they had put into certain options for users, the knowledge the team provide has been essential in my continuous learning process.
Why do I use it?
Because well, to me it’s home.
A distro, backed by a family of great people.
Well said! ![]()
I like this answer the best so far. Thanks.
Edit: Without your involvement, CachyOS might not even exist in this optimized form.
Thanks!
I saw its popularity growing, I try to pay attention to those things. My experience coming from Fedora is that everything just works better, everything feels faster and more stable, more glitch free. It feels like a more user-focused distro than others, wrapping up the ideological aspects with the proprietary to make the best end result possible right away.
It honestly feels like this distro caught all other distros slacking, and that this distro will become obsolete when other distros copy it and improve on the way it’s absolutely slapping other distros atm.
I can say for the first time using Linux, I have not encountered any glitch/bug with my setup after installation and everything has been completely smooth.
For me, it’s the default package list that is closest to what I would ideally install and which has also given me the least issues over time.
Based on the thread title, there can be no solution.
Nevertheless, I’m marking your post as the solution because it deeply impressed me.
Long time mint user. Used manjaro, parrot and Ubuntu a tiny bit. Load cachy on older pc. Not for a wide range of uses yet, but not only does it run snappy, but it runs a lot longer without slowing down. Am quite happy with it. Edit-sp
tl:dr see below
If you’re still looking for chilis, have some more: When they announced Windows 11’s recall ‘feature’, it was the straw that broke the camel’s back. Way too creepy ![]()
I had gathered some experience with Debian in the past and several years ago, I tried Ubuntu. I wasn’t very fond of the Nvidia support back then, so back to Windows it was.
And now CachyOS? Sheer coincidence that I picked this distro. A friend of mine told me about it (he reads a lot more than I do) and after failing with a classic Arch installation, I decided to give the Cachy iso a try. Boy was I in for a surprise! Not even fifteen minutes later, I had a full linux system up and running. ……for almost six months now. ![]()
I won’t go so far as to lavish praise on the mere fact that it was easy to install CachyOS. In fact, I had to learn a lot of things the hard way. I assume that applies to any new operating system you are going to switch to.
I’m glad I switched, and I’ll never go back to any OS that forces the stupidest things on me
tl;dr and those are also reasons for keeping CachyOs and not start distro hopping (order doesn’t matter)
- I really wanted to get rid of the chains that forced me into the slavery of… well, you know
- Even with half a century on this planet, there’s always room to learn something new, and I get to learn a lot of new things with CachyOS
- There’s always someone willing to help if you are stuck (given that you did your search engine homework beforehand and ask your questions nicely) (okay, applies to other distros, too)
- My entire Steam library works just fine
Conclusion: I think switching to linux is generally an option. However, that still leaves the question open, why CachyOS? Well, I recently saw a youtube short about how people choose their linux distros. Quote: “You don’t choose Arch. Arch chooses you.” In my case it was CachyOS, but I’m absolutely happy it found me when it did.
cheers,
Fryke
I used Knoppix & Linux Mint for about a year then Garuda Linux, if I remember for 888 Day’s. But a couple of changes to Garuda which I didn’t like (a personal choice) such as Garuda Rani and some theme updates made me think about CachyOS as it gets very good write-ups and reviews. Plus the Garuda Forum is not such a friendly place (again, just my opinion).
So here I am, I’ve learned a lot and me and ChatGPT are now very good friends. I never use Windows, my business Laptop is a MacBook Pro, and if I get a Windows install to fix, I try and get the owner on Linux.
80 Day’s young with CachyOS and very happy.
Years ago(2010-ish) tried a distro (Ubuntu, I think) on an old laptop, but gaming wasnt a thing then and the setup was rather involved. Linux just seemed “unfinshed” in a lot of ways.
Had learned BASIC in the 80s, took some college courses in programming which seems to help these days in the terminal.
Recently upgraded my system and after all the news and (non)development at Micro$oft, I revisited Linux options. Privacy, speed, Open source!
Tried Bazzite for couple of days…but the “immutable” was off putting.
So after reading and youtubing, CachyOS looked like the go to…Arch wiki, community, gaming plus full control.
Fresh, yet familiar… performance is great.
Near painless transition! Not looking back.
So excited to learn the ways of the Penguin.
