is genymotion supported in cachyos? its listed in the installer, but displays this error message, and i can’t download with sudo pacman either because genymotion isn’t found
It’s a package from the AUR. Not sure how you’re getting conflicts because the package doesn’t depend or conflict with anything.
Repository : aur
Version : 3.8.0-1
Description : Complete set of tools that provides a virtual environment for Android.
URL : http://www.genymotion.com/
AUR URL : https://aur.archlinux.org/packages/genymotion
Groups : None
Licenses : custom
Provides : None
Depends On : None
Make Deps : wget
Check Deps : None
Optional Deps : virtualbox
Conflicts With : None
Maintainer : j.taala
Votes : 328
Popularity : 0.568631
First Submitted : Fri, 2 Aug 2013 16:18:42
Last Modified : Tue, 5 Nov 2024 03:16:59
Out Of Date : No
manually installed from AUR, worked just fine.
The solution is probably more likely to be attributed to naim
