Hey,
I’ve been playing around with Proton, FSR4, HDR and MangoHUD on CachyOS and ended up writing a small helper script that might be useful for others too.
Instead of stuffing huge, unreadable environment strings into Steam launch options or fighting with Lutris → Steam → Proton env forwarding, this script lets you control everything with short toggles like:
HDR=1 FSR4=4.0.2 FPS=141 HUD=1 LSC=1 NVMD=1 NTS=1 CPU=16 GP=1 GM=1 \
$HOME/bin/gaming_env_wrapper.sh %command%
GitHub repo (with full README, toggle reference and details):
What problem does this solve?
Long Proton / DXVK / MangoHUD env strings in Steam are annoying to type and hard to maintain per game.
Lutris env vars don’t always reliably make it all the way through to Steam → Proton.
FSR4 on RDNA3/RDNA4 has some weird env naming quirks (
PROTON_FSR4_RDNA3_UPGRADEvsPROTON_FSR4_UPGRADE) and it’s easy to forget which is which. -
CachyOS has nice stuff like
game-performance, but wiring it per game can be tedious. -
The idea is: one script, with short toggles, that you can reuse across games and launchers.
Feedback, ideas and wishes for specific toggles or behavior improvements are very welcome — if there’s a function you’d like to see added, feel free to suggest it.
What this script does
gaming_env_wrapper.sh is a pure shell wrapper that:
- Reads short env toggles like
HDR=1,FSR4=4.0.2,FPS=141,HUD=1,ASYNC=1,CPU=16,GP=1,GM=1, etc. - Translates them into the real env vars for Proton / DXVK / Wine / MangoHUD.
- Knows about FSR4 quirks (RDNA3 vs RDNA4 env vars).
- Can optionally wrap the game in
game-performance(CachyOS) and/orgamemoderunif installed. - Finally
execs the original game command (%command%from Steam).
No sudo, no system changes – it just sets env vars and runs the game.
Example usage (Steam)
In Steam → Properties → General → Launch Options, you can do:
HDR=1 FSR4=4.0.2 FSR4SHOW=1 FPS=117 HUD=1 LSC=1 NVMD=1 NTS=1 CPU=16 GP=1 GM=1 \
Notes:
HDR=1assumes Wayland HDR is set up. On X11, leave HDR off.GP=1usesgame-performanceif present.GM=1usesgamemoderunif present.
Interactive “wizard” mode
If you run the script directly in a terminal:
# or
it starts an interactive wizard that:
- Tries to auto-detect your AMD GPU (RDNA2 / RDNA3 / RDNA4 / unknown) via
lspci. - Asks if you want HDR, which FSR4 version to use, MangoHUD on/off + FPS limit, DXVK async, local shader cache, fake CPU topology, and whether to use
game-performance/gamemoderun, etc.
At the end it prints a ready-to-paste Steam launch line, like:
=== Generated Steam launch options ===
HDR=1 FSR4=4.0.2 FPS=141 HUD=1 LSC=1 NVMD=1 NTS=1 CPU=16 GP=1 \
Installation (simple version)
Download the script:
mkdir -p "$HOME/bin" cd "$HOME/bin" curl -LO https://raw.githubusercontent.com/furbakka/gaming_env_wrapper/main/gaming_env_wrapper.sh chmod +x gaming_env_wrapper.sh -
Make sure
$HOME/binis in your PATH (fish example):set -U fish_user_paths $HOME/bin $fish_user_paths -
Verify:
which gaming_env_wrapper.sh
For the full toggle matrix (HDR/FSR4/FFSR/MangoHUD/async/NTS, etc.), RDNA detection behaviour and more examples, see the README in the GitHub repo:
