Forza Horizon 5 instant crash when using almost any proton except Proton GE 10-30 and up
So on steam I tried launching FH5 using cachyos proton or any other version (proton experimental, hotfix…) and usually it worked normally, but after one random day it just decided to not launch/crash on launch.
I click the green play button, it says launching and then it never launches and the green play button returns. But when I use Proton-GE 10-30 or 10-34 (these are the ones I installed using protonup-qt) it shows the little splash screen that forza has and it launches the game normally.
This same thing happened with marvel’s spiderman and forza horizon 6.
The only thing that would launch it was adding PROTON_USE_WINED3D=1 %command% to the launch options but then i get greeted with the error that my graphics card isnt supported.
I’ve searched everywhere for this problem but was unable to find a solution.
This is what appears in console:
chdir “/run/media/keronite/SHADOWBANE/SteamLibrary/steamapps/common/ForzaHorizon5”
ERROR: ld.so: object ‘/home/keronite/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so’ from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS3
2): ignored.
2): ignored.
ERROR: ld.so: object ‘/home/keronite/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so’ from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS6
4): ignored.
2): ignored.
2): ignored.
Game Recording - would start recording game 1551360, but recording for this game is disabled
Adding process 83526 for gameID 1551360
Adding process 83527 for gameID 1551360
Adding process 83528 for gameID 1551360
Adding process 83622 for gameID 1551360
ProtonFixes[83622] INFO: Running protonfixes on “cachyos-11.0-20260429-slr”, build at 2026-05-03 18:22:28+00:00.
ProtonFixes[83622] INFO: Running checks
ProtonFixes[83622] INFO: All checks successful
ProtonFixes[83622] INFO: Using early stage global defaults for “Forza Horizon 5” (1551360)
ProtonFixes[83622] INFO: No early stage global protonfix found for “Forza Horizon 5” (1551360)
ProtonFixes[83622] INFO: Using main stage global defaults for “Forza Horizon 5” (1551360)
ProtonFixes[83622] INFO: No main stage global protonfix found for “Forza Horizon 5” (1551360)
ntsync: up and running.
Adding process 83624 for gameID 1551360
Adding process 83625 for gameID 1551360
Adding process 83626 for gameID 1551360
Adding process 83630 for gameID 1551360
Adding process 83632 for gameID 1551360
Adding process 83635 for gameID 1551360
Adding process 83644 for gameID 1551360
Adding process 83649 for gameID 1551360
Adding process 83655 for gameID 1551360
Adding process 83661 for gameID 1551360
Adding process 83686 for gameID 1551360
Adding process 83696 for gameID 1551360
Adding process 83698 for gameID 1551360
Adding process 83718 for gameID 1551360
pid 83627 != 83626, skipping destruction (fork without exec?)
Game Recording - game stopped [gameid=1551360]
Removing process 83718 for gameID 1551360
Removing process 83698 for gameID 1551360
Removing process 83696 for gameID 1551360
Removing process 83686 for gameID 1551360
Removing process 83661 for gameID 1551360
Removing process 83655 for gameID 1551360
Removing process 83649 for gameID 1551360
Removing process 83644 for gameID 1551360
Removing process 83635 for gameID 1551360
Removing process 83632 for gameID 1551360
Removing process 83630 for gameID 1551360
Removing process 83626 for gameID 1551360
Removing process 83625 for gameID 1551360
Removing process 83624 for gameID 1551360
Removing process 83622 for gameID 1551360
Removing process 83528 for gameID 1551360
Removing process 83527 for gameID 1551360
Removing process 83526 for gameID 1551360
