Long-time Linux user here, but first time running Arch. I finally decided to escape Windows and noticed CachyOS had solid ASUS support, including the ASUS-for-Linux kernel. Installation went smoothly, and I was able to install the ROG Control Center without any extra hassle — honestly, I’m loving it so far.
That said, I’ve run into one issue. Even in Balanced mode, my fans are noticeably louder than they ever were on Windows, and this is happening even when the system is basically idle. I’m not running anything heavy, yet the fans seem to be spinning constantly.
I wanted to ask if I might be missing something obvious — maybe a sensor package, thermal service, or power management component that needs to be installed or configured? I just want to make sure I’m not overlooking something and potentially stressing the hardware unnecessarily.
Any guidance would be appreciated. Thanks in advance!
asusctl profile -P Balanced # or Silent
asusctl fan-curve --help # to see options and set curves
Monitor temps and speeds
In terminal:
sensors
asusctl fan -f
Power management extras (optional but helpful)
CachyOS is tuned for performance, so idle power might be slightly higher than ultra-optimized setups.
Install/enable TLP if not already (common on laptops):
thank you for the reply i went through these steps and im not seeing anything out of the ordinary but yet the fans still seem to be running a little to much any other suggestions and TLP is installed
sensors
ucsi_source_psy_USBC000:002-isa-0000
Adapter: ISA adapter
in0: 0.00 V (min = +0.00 V, max = +0.00 V)
curr1: 0.00 A (max = +0.00 A)
