Hello, after having a package fail to update due to insufficient space, I was able to get my computer working again. However, now that package always throws errors during my updates and during this most recent update attempt stopped me from updating at all. How can I update or fix this package, ideally without a full reinstall.
I am not sure how to best share this. After inputting those first 2 commands, I attempted the 3rd. It goes through the update, allows me to input password, then gives me a giant list followed by “errors occurred, no packages were upgraded.” Looking at the ones listed, it seems that these files still exist in the filesystem. I imagine somewhere I can find an error log but the konsole doesn’t have enough space to display all the error messages.
Please show the whole thing somehow if possible .. you can also use a pastebin service if it is quite large, ex;
(besides the script there is also a link to a bunch of services you can use yourself)
We can just tell pacman to overwrite everything but it would be better if we could give it a particular scope of paths. Assuming thats the only issue afoot.
When using the first command I get the error “error: target not found: breeze-icons” but attempting the second command still give the same errors from before
