Failed to mount sysroot
hi,
every time when i want to boot my system, the mount for /boot, swap and zram0 are timed out, and it is impossible to login on a graphical session nor TTy :frowning:
my fstab is crated by genfstab
/dev/nvme0n1p1          /               f2fs            rw,relatime,lazytime,background_gc=on,nogc_merge,discard,discard_unit=block,inline_xattr,inline_data,inline_dentry,flush_merge,barrier,extent_cache,mode=adaptive,active_logs=6,alloc_mode=default,checkpoint_merge,fsync_mode=posix,memory=normal,errors=continue  0 0
# UUID=A5A0-DF57 LABEL=BOOT
/dev/nvme0n1p2          /boot           vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro 0 2
# UUID=8a60f4ea-1c05-4438-a05d-3c9de5dd0c17 LABEL=zram0
/dev/zram0              none            swap            defaults,pri=100        0 0
# UUID=9c6decb8-7560-470a-9090-87306a4df1e3
/dev/nvme0n1p3          none            swap            defaults        0 0
edit:
in short: boot notification says: failed to mount sysroot, and missing dependencies for /, /boot and swap
the journal:
-- Boot 73a7555eaeda422f86523c485df55914 --
[    1.432735] donar kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
[    1.433249] donar kernel: ACPI Error: AE_NOT_FOUND, While resolving a named referen
ce package element - ^SPI1.SPFD.CVFD (20240827/dspkginit-438)
[    1.433255] donar kernel: ACPI Error: AE_NOT_FOUND, While resolving a named referen
[    1.433261] donar kernel: ACPI Error: AE_NOT_FOUND, While resolving a named referen
ce package element - ^XHCI.RHUB.HS04.VI2C (20240827/dspkginit-438)
[    1.433267] donar kernel: ACPI Error: AE_NOT_FOUND, While resolving a named referen
[   91.537663] donar systemd[1]: Timed out waiting for device /dev/nvme0n1p3.
[   91.539035] donar systemd[1]: Timed out waiting for device /dev/zram0.
-- Boot ea9198b744314be3a7f2bdcbfd1d5e93 --
[ 6315.951234] donar systemd-tmpfiles[47]: Failed to open file "/sys/module/zswap/para
meters/enabled": Read-only file system
[ 6315.955849] donar systemd-tmpfiles[47]: Failed to open file "/sys/class/rtc/rtc0/ma
x_user_freq": Read-only file system
[ 6315.955883] donar systemd-tmpfiles[47]: Failed to open file "/proc/sys/dev/hpet/max
-user-freq": Read-only file system
[ 6315.957745] donar systemd-tmpfiles[47]: Failed to open file "/sys/kernel/mm/transpa
rent_hugepage/khugepaged/max_ptes_none": Read-only file system
[ 6315.957776] donar systemd-tmpfiles[47]: Failed to open file "/sys/kernel/mm/transpa
rent_hugepage/defrag": Read-only file system
[ 6316.008499] donar systemd-resolved[53]: LLMNR-IPv4(TCP): Failed to bind socket: Add
ress already in use
[ 6316.165008] donar systemd-coredump[82]: [🡕] Process 59 (ananicy
-cpp) of user 0 dumped core.
                                           Stack trace of thread 59:
                                           #0  0x0000609046b1675b n/a (n/a + 0x0)
                                           ELF object binary architecture: AMD x86-64
[ 6336.277595] donar (powertop)[164]: powertop.service: Failed at step EXEC spawning /
usr/bin/powertop: No such file or directory
edit
tom@donar ~ % systemctl status systemd-remount-fs.service
× systemd-remount-fs.service - Remount Root and Kernel File Systems
     Loaded: loaded (/usr/lib/systemd/system/systemd-remount-fs.service; enabled-runtime; preset: disabled)
     Active: failed (Result: exit-code) since Sun 2025-01-05 12:45:42 UTC; 2min 35s ago
 Invocation: 36a7933274334886908d48082c6f0bec
       Docs: man:systemd-remount-fs.service(8)
             https://systemd.io/API_FILE_SYSTEMS
    Process: 24 ExecStart=/usr/lib/systemd/systemd-remount-fs (code=exited, status=1/FAILURE)
   Main PID: 24 (code=exited, status=1/FAILURE)
   Mem peak: 1.5M
        CPU: 6ms
Jan 05 12:45:42 donar systemd-remount-fs[31]: mount: /: can't find UUID=f2a770c0-e7ad-40da-81ab-9f7850aac736.
