Extreme low fps on Indiana Jones The Great Circle | proton-cachyos
I’m getting very low fps, even in the menu, with all the optimizations done, which works in almost every other title so far, without any problems.
Appears to be a known issue with Nvidia drivers on Linux
Until NVIDIA fixes the issue, set:
__GL_13ebad=0x1 %command%
As your Launch options
So far, the only thing that is not available in the game, are frame generation, even if you try to emulate as a RTX40 with GA100.
