Error when installing on existing luks btrfs partition wihtout reformatting
I’d like to install cachyos to a computer that has already a btrfs partition in luks , without reformatting. I don’t want to reformat for avoiding losing my home subvolume with valuable stuff.
Setup:
  • gpt partition
  • refid boot mananger
  • partitions:
    • /boot/efi,
    • /boot,
    • swap and
    • btrfs mounted as /
  • plasma
Error message:
2024-09-22 - 11:59:44 [6]: virtual Calamares::JobResult AutoMountManagementJob::exec()
2024-09-22 - 11:59:44 [6]:     Set automount to disable
2024-09-22 - 11:59:44 [1]: void {anonymous}::PowerManagementInterface::inhibitDBusCallFinished(QDBusPendingCallWatcher*)
2024-09-22 - 11:59:44 [1]:     ERROR: Could not inhibit sleep: QDBusError("org.freedesktop.DBus.Error.ServiceUnknown", "The name org.freedesktop.PowerManagement.Inhibit was not provided by any .service files")
2024-09-22 - 11:59:44 [6]: std::shared_ptr<Calamares::Partition::AutoMountInfo> Calamares::Partition::automountDisable(bool)
2024-09-22 - 11:59:44 [6]:     Setting Solid automount to disabled
2024-09-22 - 11:59:44 [6]:     .. 2 reply QList()
2024-09-22 - 11:59:44 [6]:     .. 2 reply QList(QVariant(bool, false))
2024-09-22 - 11:59:44 [6]: virtual void Calamares::JobThread::run()
2024-09-22 - 11:59:44 [6]:     Starting job "Borrando todos los puntos de montaje temporales..." ( 2 / 40 )
2024-09-22 - 11:59:44 [6]:     Starting job "Borrar los puntos de montaje para las operaciones de particionado en «/dev/nvme0n1»" ( 3 / 40 )
2024-09-22 - 11:59:44 [6]: QStringList getPartitionsForDevice(const QString&)
2024-09-22 - 11:59:44 [6]:     Reading from "/proc/partitions" looking for "nvme0n1"
2024-09-22 - 11:59:44 [6]: virtual Calamares::JobResult ClearMountsJob::exec()
2024-09-22 - 11:59:44 [6]:     ClearMountsJob finished. Here's what was done:
2024-09-22 - 11:59:44 [6]:     .. Running QList("udevadm", "settle")
2024-09-22 - 11:59:44 [6]:     .. Running QList("sync")
2024-09-22 - 11:59:45 [6]: virtual void Calamares::JobThread::run()
2024-09-22 - 11:59:45 [6]:     Starting job "Establecer la información de la partición" ( 4 / 40 )
2024-09-22 - 11:59:45 [6]: QVariantList FillGlobalStorageJob::createPartitionList() const
2024-09-22 - 11:59:45 [6]:     Building partition information map
2024-09-22 - 11:59:45 [6]:     .. partitions on "/dev/nvme0n1"
2024-09-22 - 11:59:45 [6]:     ..  mapping for "/dev/nvme0n1p1" "/dev/nvme0n1p1"
     partlabel :   "EFI System Partition"
     partition-uuid (partuuid) :   "PartUUID$d48f171"
     parttype :   "C12A7328-F81F-11D2-BA4B-00A0C93EC93B"
     partattrs :   "0"
     mountPoint: :   "/boot/efi"
     fs: :   "fat32"
     fsName :   "fat32"
     filesystem-uuid (uuid) :   "FSUUID$cb56c31b"
     claimed :   "false"
2024-09-22 - 11:59:45 [6]:     ..  mapping for "/dev/nvme0n1p2" "/dev/nvme0n1p2"
     partlabel :   ""
     partition-uuid (partuuid) :   "PartUUID$3ce35bfb"
     parttype :   "0FC63DAF-8483-4772-8E79-3D69D8477DE4"
     partattrs :   "0"
     mountPoint: :   "/"
     fs: :   "btrfs"
     fsName :   "btrfs"
     filesystem-uuid (uuid) :   "FSUUID$24d91383"
     claimed :   "false"
     luksMapperName: :   "luks-20d763dd-2a7b-4628-ab8a-ec5f1b8378ca"
2024-09-22 - 11:59:45 [6]:     ..  mapping for "/dev/nvme0n1p3" "/dev/nvme0n1p3"
     partlabel :   ""
     partition-uuid (partuuid) :   "PartUUID$eb797043"
     parttype :   "0657FD6D-A4AB-43C4-84E5-0933C84B4F4F"
     partattrs :   "0"
     mountPoint: :   ""
     fs: :   "linuxswap"
     fsName :   "linuxswap"
     filesystem-uuid (uuid) :   "FSUUID$34d00f3d"
     claimed :   "false"
2024-09-22 - 11:59:45 [6]:     ..  mapping for "/dev/nvme0n1p4" "/dev/nvme0n1p4"
     partlabel :   ""
     partition-uuid (partuuid) :   "PartUUID$beecb123"
     partattrs :   "0"
     mountPoint: :   "/boot"
     fs: :   "ext4"
     fsName :   "ext4"
     filesystem-uuid (uuid) :   "FSUUID$72e33868"
     claimed :   "false"
2024-09-22 - 11:59:45 [6]:     .. partitions on "/dev/sda"
2024-09-22 - 11:59:45 [6]:     ..  mapping for "/dev/sda1" "/dev/sda1"
     partlabel :   ""
     partition-uuid (partuuid) :   "PartUUID$4f16e833"
     parttype :   ""
     partattrs :   "0"
     mountPoint: :   ""
     fs: :   "exfat"
     fsName :   "exfat"
     filesystem-uuid (uuid) :   "FSUUID$56dd6d12"
     claimed :   "false"
2024-09-22 - 11:59:45 [6]:     ..  mapping for "/dev/sda2" "/dev/sda2"
     partlabel :   ""
     parttype :   ""
     partattrs :   "0"
     mountPoint: :   ""
     fs: :   "fat16"
     fsName :   "fat16"
     filesystem-uuid (uuid) :   "FSUUID$96ed7fbc"
     claimed :   "false"
2024-09-22 - 11:59:45 [6]: virtual Calamares::JobResult FillGlobalStorageJob::exec()
2024-09-22 - 11:59:45 [6]:     Saving partition information map to GlobalStorage["partitions"]
2024-09-22 - 11:59:45 [6]:     FillGlobalStorageJob writing empty bootLoader value
2024-09-22 - 11:59:45 [6]:     Starting job "Gestionando la configuración de montaje automático..." ( 5 / 40 )
2024-09-22 - 11:59:45 [6]: virtual Calamares::JobResult AutoMountManagementJob::exec()
2024-09-22 - 11:59:45 [6]:     Restore automount settings
2024-09-22 - 11:59:45 [6]:     .. 2 reply QList()
2024-09-22 - 11:59:45 [6]:     .. 2 reply QList(QVariant(bool, false))
2024-09-22 - 11:59:45 [6]:     Starting job "Creando grupos y conjuntos de datos ZFS..." ( 6 / 40 )
2024-09-22 - 11:59:45 [6]:     Starting job "mount" ( 7 / 40 )
2024-09-22 - 11:59:45 [6]: virtual Calamares::JobResult Calamares::PythonJob::exec()
2024-09-22 - 11:59:45 [6]:     Job file "/usr/lib/calamares/modules/mount/main.py"
2024-09-22 - 11:59:45 [6]: [PYTHON JOB]: Found gettext "es" in "/usr/share/locale/es"
2024-09-22 - 11:59:45 [6]:     .. Job description from pretty_name "mount" = "Montando las particiones."
2024-09-22 - 11:59:45 [6]:     .. Running QList("mount", "-t", "btrfs", "-o", "defaults,noatime,compress=zstd,commit=120", "/dev/mapper/luks-20d763dd-2a7b-4628-ab8a-ec5f1b8378ca", "/tmp/calamares-root-8gla91zd/")
2024-09-22 - 11:59:45 [6]:     .. Running QList("udevadm", "settle")
2024-09-22 - 11:59:45 [6]:     .. Running QList("sync")
2024-09-22 - 11:59:45 [6]: Python Error:
 <class 'subprocess.CalledProcessError'>
 None
 File "/usr/lib/calamares/modules/mount/main.py", line 384, in run
    mount_partition(root_mount_point, partition, partitions, mount_options, mount_options_list, efi_location)
  File "/usr/lib/calamares/modules/mount/main.py", line 292, in mount_partition
    subprocess.check_call(["btrfs", "subvolume", "create",
  File "/usr/lib/python3.12/subprocess.py", line 413, in check_call
    raise CalledProcessError(retcode, cmd)
2024-09-22 - 11:59:45 [6]:     Skipping non-emergency job "modify 90-mkinitcpio-install.hook on host and chroot"
2024-09-22 - 11:59:45 [6]:     ..  Skipping non-emergency job "inicializar pacman ... ranking mirrors ... copiar pacman mirrorlist y llavero al objetivo ..."
2024-09-22 - 11:59:45 [6]:     ..  Skipping non-emergency job "pacstrap"
2024-09-22 - 11:59:45 [6]:     ..  Skipping non-emergency job "Generar el identificador único de máquina."
2024-09-22 - 11:59:45 [6]:     ..  Skipping non-emergency job "Configurando uso horario a Europe/Madrid..."
2024-09-22 - 11:59:45 [6]:     ..  Skipping non-emergency job "Configurando el modelo de teclado en pc105, diseño como us-…"
2024-09-22 - 11:59:45 [6]:     ..  Skipping non-emergency job "localecfg"
2024-09-22 - 11:59:45 [6]:     ..  Skipping non-emergency job "Preparación de su sistema para la instalación en línea de CachyOS"
2024-09-22 - 11:59:45 [6]:     ..  Skipping non-emergency job "chwd"
2024-09-22 - 11:59:45 [6]:     ..  Skipping non-emergency job "packages"
2024-09-22 - 11:59:45 [6]:     ..  Skipping non-emergency job "Configurando archivo de claves LUKS."
2024-09-22 - 11:59:45 [6]:     ..  Skipping non-emergency job "Configurando la memoria de intercambio («swap») cifrada."
2024-09-22 - 11:59:45 [6]:     ..  Skipping non-emergency job "fstab"
2024-09-22 - 11:59:45 [6]:     ..  Skipping non-emergency job "plymouthcfg"
2024-09-22 - 11:59:45 [6]:     ..  Skipping non-emergency job "zfshostid"
2024-09-22 - 11:59:45 [6]:     ..  Skipping non-emergency job "initcpiocfg"
2024-09-22 - 11:59:45 [6]:     ..  Skipping non-emergency job "Creando initramfs con mkinitcpio…"
2024-09-22 - 11:59:45 [6]:     ..  Skipping non-emergency job "Configurando usuarios <pre> sudo</pre>…"
2024-09-22 - 11:59:45 [6]:     ..  Skipping non-emergency job "Preparando grupos..."
2024-09-22 - 11:59:45 [6]:     ..  Skipping non-emergency job "Crear el usuario david"
2024-09-22 - 11:59:45 [6]:     ..  Skipping non-emergency job "Definir contraseña para el usuario david."
2024-09-22 - 11:59:45 [6]:     ..  Skipping non-emergency job "Definir contraseña para el usuario root."
2024-09-22 - 11:59:45 [6]:     ..  Skipping non-emergency job "Hostname: peque"
2024-09-22 - 11:59:45 [6]:     ..  Skipping non-emergency job "networkcfg"
2024-09-22 - 11:59:45 [6]:     ..  Skipping non-emergency job "displaymanager"
2024-09-22 - 11:59:45 [6]:     ..  Skipping non-emergency job "hwclock"
2024-09-22 - 11:59:45 [6]:     ..  Skipping non-emergency job "Remove unneeded ucode"
2024-09-22 - 11:59:45 [6]:     ..  Skipping non-emergency job "bootloader"
2024-09-22 - 11:59:45 [6]:     ..  Skipping non-emergency job "reset 90-mkinitcpio-install.hook"
2024-09-22 - 11:59:45 [6]:     ..  Skipping non-emergency job "services-systemd"
2024-09-22 - 11:59:45 [6]:     ..  Skipping non-emergency job "Ejecutando procesos de shell..."
2024-09-22 - 11:59:45 [6]:     ..  Skipping non-emergency job "Enable the UFW Firewall as default and allow outgoing but deny incoming"
2024-09-22 - 11:59:45 [6]:     ..  Starting EMERGENCY JOB "Desmontando sistemas de archivos..." ( 40 / 40 )
2024-09-22 - 11:59:45 [1]: void Calamares::ViewManager::onInstallationFailed(const QString&, const QString&)
2024-09-22 - 11:59:45 [1]:     ERROR: Installation failed: "Error Boost.Python en el proceso \"mount\"."
2024-09-22 - 11:59:45 [6]:     .. - message: "Error Boost.Python en el proceso \"mount\"."
2024-09-22 - 11:59:45 [6]:     .. - details: <div><strong>Command '['btrfs', 'subvolume', 'create', '/tmp/calamares-root-8gla91zd/@']' returned non-zero exit status 1.</strong></div><div>None</div><div><br/>Traceback:</div><div><pre>File &quot;/usr/lib/calamares/modules/mount/main.py&quot;, line 384, in run
  File &quot;/usr/lib/calamares/modules/mount/main.py&quot;, line 292, in mount_partition
    subprocess.check_call([&quot;btrfs&quot;, &quot;subvolume&quot;, &quot;create&quot;,
  File &quot;/usr/lib/python3.12/subprocess.py&quot;, line 413, in check_call
    raise CalledProcessError(retcode, cmd)</pre></div>
2024-09-22 - 11:59:45 [6]: void Calamares::ViewManager::onInstallationFailed(const QString&, const QString&)
2024-09-22 - 11:59:45 [6]:     Calamares will quit when the dialog closes.
2024-09-22 - 11:59:45 [6]: DEBUG (Qt): QML Component (default slideshow) deactivated
2024-09-22 - 11:59:45 [6]: void Config::doNotify(bool, bool)
2024-09-22 - 11:59:45 [6]:     Notification not sent; completion: failed
2024-09-22 - 11:59:45 [6]: void {anonymous}::PowerManagementInterface::uninhibitSleep()
2024-09-22 - 11:59:45 [6]:     Sleep was never inhibited.
In addiiton, it seems I have no control on how subvolumes are handled and mount options (compression, …).
Thanks, I didn’t know I could install manually. Next reinstallation I will try.
Finally, I’ve created two partionons:
  • btrfs, that I will mount as /
  • encrpyted btrfs that I mount as /home
By the way, the installer hasn’t setup well how to mount /home.
So, the system has become unbootlable.
I’ve had to modify manually, /etc/crypttab and /etc/fstab, in order to make it bootable.
Thanksfully, I have the knowledge.
