I’m trying to update my system but each time I try I get the same error.
Console log:
sudo pacman -Syu
[sudo] password for dsmario64:
:: Synchronizing package databases…
cachyos-v3 is up to date
cachyos-core-v3 is up to date
cachyos is up to date
core is up to date
extra is up to date
multilib is up to date
warning: glew1.10: local (1.10.0-4.1) is newer than extra (1.10.0-4)
warning: grub: local (2:2.12.r418.g6b5c671d-2.1) is newer than core (2:2.12.r418.g6b5c671d-2)
warning: gst-libav: local (1.26.7-1.1) is newer than extra (1.26.7-1)
warning: gst-plugins-bad: local (1.26.7-1.1) is newer than extra (1.26.7-1)
warning: gst-plugins-bad-libs: local (1.26.7-1.1) is newer than extra (1.26.7-1)
warning: gst-plugins-base: local (1.26.7-1.1) is newer than extra (1.26.7-1)
warning: gst-plugins-base-libs: local (1.26.7-1.1) is newer than extra (1.26.7-1)
warning: gst-plugins-good: local (1.26.7-1.1) is newer than extra (1.26.7-1)
warning: gst-plugins-ugly: local (1.26.7-1.1) is newer than extra (1.26.7-1)
warning: gstreamer: local (1.26.7-1.1) is newer than extra (1.26.7-1)
warning: knotifyconfig: local (6.19.0-1.1) is newer than extra (6.19.0-1)
warning: krita: local (5.2.13-2.1) is newer than extra (5.2.13-1)
warning: libjpeg6-turbo: local (1.5.3-2.2) is newer than extra (1.5.3-2)
warning: libpng12: local (1.2.59-2.1) is newer than cachyos (1.2.59-2)
warning: librtmp0: local (2.4-6.1) is newer than extra (2.4-6)
warning: libudev0-shim: local (2-1.1) is newer than extra (2-1)
warning: ostree: local (2025.6-1.1) is newer than extra (2025.6-1)
resolving dependencies…
warning: cannot resolve “libmakepkg-dropins”, a dependency of “pacman”
warning: cannot resolve “libfilezilla.so=51-64”, a dependency of “filezilla”
:: The following packages cannot be upgraded due to unresolvable dependencies:
filezilla pacman
:: Do you want to skip the above packages for this upgrade? [y/N] y
:: installing audit (4.1.2-1.1) breaks dependency ‘audit=4.0.5’ required by lib32-audit
:: installing libcap (2.77-1.1) breaks dependency ‘libcap=2.76’ required by lib32-libcap
Note: I do have a stable internet connection
I tried googling and checking the forums for this, so if this issue has cropped up before I was not able to find it. Call it a skill issue if I missed it.
