Emudeck not installing flatpak emulators
Hello, I had cachyos handheld edition on my gpd win mini working fine for 3 months but I decided to do a fresh install so I can dual boot with windows. Now that I have a fresh install, I cannot get Emudeck to download and install the flatpak emulators. It will download the appimage emulators just fine such as rpcs3, cemu but it will not download the flatpak emulators such as Retroarch, dolphin. It keeps failing. Something changed with the new release because this was working fine a few months ago. I can manually install Retroarch with octopi but then I have to configure it while emudeck does it all for you. Anyone knows the fix? Thanks.
I figured it out, for anyone that has this issue. Open the Konsole terminal and type in sudo pacman -S flatpak
After that emudeck was able to download all flatpack emulators.
