Eduroam failure to connect
System:
Host: IUCLap Kernel: 6.17.5-2-cachyos arch: x86_64 bits: 64 compiler: clang
v: 21.1.3 clocksource: tsc
Desktop: KDE Plasma v: 6.5.0 tk: Qt v: N/A wm: kwin_wayland with: krunner
vt: 2 dm: SDDM Distro: CachyOS base: Arch Linux
Machine:
Type: Laptop System: LENOVO product: 20AMS0SQ0C v: ThinkPad X240
serial: <superuser required> Chassis: type: 10 serial: <superuser required>
Mobo: LENOVO model: 20AMS0SQ0C serial: <superuser required>
part-nu: LENOVO_MT_20AM_BU_Think_FM_ThinkPad X240 uuid: <superuser required>
UEFI-[Legacy]: LENOVO v: GIET73WW (2.23 ) date: 04/10/2014
Battery:
ID-1: BAT1 charge: 39.8 Wh (99.5%) condition: 40/47.5 Wh (84.2%)
volts: 12.33 min: 10.8 model: SANYO 45N1767 type: Li-ion serial: 1616
charging: status: not charging control: start: 0% end: 100% cycles: N/A
CPU:
Info: dual core model: Intel Core i5-4300U bits: 64 type: MT MCP
smt: enabled arch: Haswell rev: 1 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 800 min/max: 800/2900 cores: 1: 800 2: 800 3: 800 4: 800
bogomips: 19953
Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Graphics:
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Lenovo ThinkPad X240
driver: i915 v: kernel arch: Gen-7.5 ports: active: eDP-1 empty: DP-1,
DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:0a16 class-ID: 0300
Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 bus-ID: 2-8:5 chip-ID: 04f2:b39a class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.18 with: Xwayland v: 24.1.8
compositor: kwin_wayland driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: LG Display 0x03cd res: mode: 1366x768 hz: 60
scale: 100% (1) dpi: 125 size: 277x156mm (10.91x6.14") diag: 318mm (12.5")
modes: 1366x768
API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus wayland:
drv: crocus x11: drv: crocus
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.5-cachyos1.5
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4400 (HSW
GT2) device-ID: 8086:0a16 display-ID: :0.0
API: Vulkan v: 1.4.328 layers: 1 surfaces: N/A device: 0
type: integrated-gpu driver: mesa intel device-ID: 8086:0a16
de: kscreen-console,kscreen-doctor wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Audio:
Device-1: Intel Haswell-ULT HD Audio vendor: Lenovo ThinkPad X240
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c
class-ID: 0403
Device-2: Intel 8 Series HD Audio vendor: Lenovo ThinkPad X240
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20
class-ID: 0403
API: ALSA v: k6.17.5-2-cachyos status: kernel-api
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
Network:
Device-1: Intel Ethernet I218-LM vendor: Lenovo ThinkPad X240 driver: e1000e
v: kernel port: 3080 bus-ID: 00:19.0 chip-ID: 8086:155a class-ID: 0200
IF: enp0s25 state: up speed: 1000 Mbps duplex: full mac: 28:d2:44:be:26:0c
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel pcie:
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:08b2 class-ID: 0280
IF: wlan0 state: down mac: 2a:60:18:8a:75:0b
Bluetooth:
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 bus-ID: 2-7:4 chip-ID: 8087:07dc
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: 28:B2:BD:8B:DF:B6
bt-v: 4.0 lmp-v: 6 class-ID: 6c010c
Drives:
Local Storage: total: 117.38 GiB used: 11.43 GiB (9.7%)
ID-1: /dev/sda vendor: SanDisk model: SDSSDP128G size: 117.38 GiB
speed: 6.0 Gb/s tech: SSD serial: 135275401075 scheme: MBR
Partition:
ID-1: / size: 117.38 GiB used: 11.43 GiB (9.7%) fs: btrfs dev: /dev/sda1
ID-2: /home size: 117.38 GiB used: 11.43 GiB (9.7%) fs: btrfs
dev: /dev/sda1
ID-3: /var/log size: 117.38 GiB used: 11.43 GiB (9.7%) fs: btrfs
dev: /dev/sda1
ID-4: /var/tmp size: 117.38 GiB used: 11.43 GiB (9.7%) fs: btrfs
dev: /dev/sda1
Swap:
ID-1: swap-1 type: zram size: 7.45 GiB used: 0 KiB (0.0%) priority: 100
dev: /dev/zram0
Sensors:
System Temperatures: cpu: 51.0 C mobo: N/A
Fan Speeds (rpm): fan-1: 3296
Info:
Memory: total: 8 GiB note: est. available: 7.45 GiB used: 2.79 GiB (37.4%)
Processes: 212 Power: uptime: 36m states: freeze,mem,disk suspend: deep
wakeups: 0 hibernate: platform Init: systemd v: 258 default: graphical
Packages: pm: pacman pkgs: 1330 Compilers: clang: 21.1.4 gcc: 15.2.1
Shell: fish v: 4.1.2 running-in: konsole inxi: 3.3.39
The journalctl report is below:
sudo journalctl -u NetworkManager -f | grep -i eduroam
Eki 27 11:18:19 IUCLap NetworkManager[572]: <warn>  [1761553099.1365] device (wlan0): Activation: failed for connection 'eduroam'
Eki 27 11:18:48 IUCLap NetworkManager[572]: <info>  [1761553128.3696] device (wlan0): Activation: starting connection 'eduroam' (26d4b586-8d47-4fcc-a6e0-403809bfdfb8)
Eki 27 11:18:48 IUCLap NetworkManager[572]: <info>  [1761553128.3697] audit: op="connection-activate" uuid="26d4b586-8d47-4fcc-a6e0-403809bfdfb8" name="eduroam" pid=992 uid=1000 result="success"
Eki 27 11:18:48 IUCLap NetworkManager[572]: <info>  [1761553128.3892] device (wlan0): Activation: (wifi) access point 'eduroam' has security, but secrets are required.
Eki 27 11:18:48 IUCLap NetworkManager[572]: <info>  [1761553128.3914] device (wlan0): Activation: (wifi) connection 'eduroam' has security, and secrets exist.  No new secrets needed.
Eki 27 11:18:48 IUCLap NetworkManager[572]: <info>  [1761553128.3914] Config: added 'ssid' value 'eduroam'
Eki 27 11:19:14 IUCLap NetworkManager[572]: <warn>  [1761553154.1407] device (wlan0): Activation: failed for connection 'eduroam'
Eki 27 11:19:17 IUCLap NetworkManager[572]: <info>  [1761553157.3162] policy: auto-activating connection 'eduroam' (26d4b586-8d47-4fcc-a6e0-403809bfdfb8)
Eki 27 11:19:17 IUCLap NetworkManager[572]: <info>  [1761553157.3191] device (wlan0): Activation: starting connection 'eduroam' (26d4b586-8d47-4fcc-a6e0-403809bfdfb8)
Eki 27 11:19:17 IUCLap NetworkManager[572]: <info>  [1761553157.3306] device (wlan0): Activation: (wifi) access point 'eduroam' has security, but secrets are required.
Eki 27 11:19:17 IUCLap NetworkManager[572]: <info>  [1761553157.3330] device (wlan0): Activation: (wifi) connection 'eduroam' has security, and secrets exist.  No new secrets needed.
Eki 27 11:19:17 IUCLap NetworkManager[572]: <info>  [1761553157.3332] Config: added 'ssid' value 'eduroam'
Eki 27 11:19:42 IUCLap NetworkManager[572]: <warn>  [1761553182.1405] device (wlan0): Activation: failed for connection 'eduroam'
Eki 27 11:19:45 IUCLap NetworkManager[572]: <info>  [1761553185.3200] policy: auto-activating connection 'eduroam' (26d4b586-8d47-4fcc-a6e0-403809bfdfb8)
Eki 27 11:19:45 IUCLap NetworkManager[572]: <info>  [1761553185.3207] device (wlan0): Activation: starting connection 'eduroam' (26d4b586-8d47-4fcc-a6e0-403809bfdfb8)
Eki 27 11:19:45 IUCLap NetworkManager[572]: <info>  [1761553185.3363] device (wlan0): Activation: (wifi) access point 'eduroam' has security, but secrets are required.
Eki 27 11:19:45 IUCLap NetworkManager[572]: <info>  [1761553185.3401] device (wlan0): Activation: (wifi) connection 'eduroam' has security, and secrets exist.  No new secrets needed.
Eki 27 11:19:45 IUCLap NetworkManager[572]: <info>  [1761553185.3402] Config: added 'ssid' value 'eduroam'
Eki 27 11:20:10 IUCLap NetworkManager[572]: <warn>  [1761553210.1356] device (wlan0): Activation: failed for connection 'eduroam'
Eki 27 11:20:13 IUCLap NetworkManager[572]: <info>  [1761553213.3157] policy: auto-activating connection 'eduroam' (26d4b586-8d47-4fcc-a6e0-403809bfdfb8)
Eki 27 11:20:13 IUCLap NetworkManager[572]: <info>  [1761553213.3171] device (wlan0): Activation: starting connection 'eduroam' (26d4b586-8d47-4fcc-a6e0-403809bfdfb8)
Eki 27 11:20:13 IUCLap NetworkManager[572]: <info>  [1761553213.3311] device (wlan0): Activation: (wifi) access point 'eduroam' has security, but secrets are required.
Eki 27 11:20:13 IUCLap NetworkManager[572]: <info>  [1761553213.3356] device (wlan0): Activation: (wifi) connection 'eduroam' has security, and secrets exist.  No new secrets needed.
Eki 27 11:20:13 IUCLap NetworkManager[572]: <info>  [1761553213.3358] Config: added 'ssid' value 'eduroam'
Eki 27 11:20:38 IUCLap NetworkManager[572]: <warn>  [1761553238.1347] device (wlan0): Activation: failed for connection 'eduroam'
Eki 27 11:25:38 IUCLap NetworkManager[572]: <info>  [1761553538.1234] policy: auto-activating connection 'eduroam' (26d4b586-8d47-4fcc-a6e0-403809bfdfb8)
Eki 27 11:25:38 IUCLap NetworkManager[572]: <info>  [1761553538.1247] device (wlan0): Activation: starting connection 'eduroam' (26d4b586-8d47-4fcc-a6e0-403809bfdfb8)
Eki 27 11:25:38 IUCLap NetworkManager[572]: <info>  [1761553538.1405] device (wlan0): Activation: (wifi) access point 'eduroam' has security, but secrets are required.
Eki 27 11:25:38 IUCLap NetworkManager[572]: <info>  [1761553538.1434] device (wlan0): Activation: (wifi) connection 'eduroam' has security, and secrets exist.  No new secrets needed.
Eki 27 11:25:38 IUCLap NetworkManager[572]: <info>  [1761553538.1434] Config: added 'ssid' value 'eduroam'
Eki 27 11:26:20 IUCLap NetworkManager[572]: <info>  [1761553580.9098] device (wlan0): Activation: (wifi) connection 'eduroam' has security, and secrets exist.  No new secrets needed.
Eki 27 11:26:20 IUCLap NetworkManager[572]: <info>  [1761553580.9098] Config: added 'ssid' value 'eduroam'
Eki 27 11:26:46 IUCLap NetworkManager[572]: <warn>  [1761553606.1424] device (wlan0): Activation: failed for connection 'eduroam'
Eki 27 11:26:49 IUCLap NetworkManager[572]: <info>  [1761553609.3205] policy: auto-activating connection 'eduroam' (26d4b586-8d47-4fcc-a6e0-403809bfdfb8)
Eki 27 11:26:49 IUCLap NetworkManager[572]: <info>  [1761553609.3227] device (wlan0): Activation: starting connection 'eduroam' (26d4b586-8d47-4fcc-a6e0-403809bfdfb8)
Eki 27 11:26:49 IUCLap NetworkManager[572]: <info>  [1761553609.3324] device (wlan0): Activation: (wifi) access point 'eduroam' has security, but secrets are required.
Eki 27 11:26:49 IUCLap NetworkManager[572]: <info>  [1761553609.3354] device (wlan0): Activation: (wifi) connection 'eduroam' has security, and secrets exist.  No new secrets needed.
Eki 27 11:26:49 IUCLap NetworkManager[572]: <info>  [1761553609.3356] Config: added 'ssid' value 'eduroam'
Eki 27 11:27:14 IUCLap NetworkManager[572]: <warn>  [1761553634.1325] device (wlan0): Activation: failed for connection 'eduroam'
Eki 27 11:27:17 IUCLap NetworkManager[572]: <info>  [1761553637.3059] policy: auto-activating connection 'eduroam' (26d4b586-8d47-4fcc-a6e0-403809bfdfb8)
Eki 27 11:27:17 IUCLap NetworkManager[572]: <info>  [1761553637.3075] device (wlan0): Activation: starting connection 'eduroam' (26d4b586-8d47-4fcc-a6e0-403809bfdfb8)
Eki 27 11:27:17 IUCLap NetworkManager[572]: <info>  [1761553637.3198] device (wlan0): Activation: (wifi) access point 'eduroam' has security, but secrets are required.
Eki 27 11:27:17 IUCLap NetworkManager[572]: <info>  [1761553637.3240] device (wlan0): Activation: (wifi) connection 'eduroam' has security, and secrets exist.  No new secrets needed.
Eki 27 11:27:17 IUCLap NetworkManager[572]: <info>  [1761553637.3240] Config: added 'ssid' value 'eduroam'
Eki 27 11:27:42 IUCLap NetworkManager[572]: <warn>  [1761553662.1383] device (wlan0): Activation: failed for connection 'eduroam'
Eki 27 11:27:45 IUCLap NetworkManager[572]: <info>  [1761553665.3131] policy: auto-activating connection 'eduroam' (26d4b586-8d47-4fcc-a6e0-403809bfdfb8)
Eki 27 11:27:45 IUCLap NetworkManager[572]: <info>  [1761553665.3155] device (wlan0): Activation: starting connection 'eduroam' (26d4b586-8d47-4fcc-a6e0-403809bfdfb8)
Eki 27 11:27:45 IUCLap NetworkManager[572]: <info>  [1761553665.3287] device (wlan0): Activation: (wifi) access point 'eduroam' has security, but secrets are required.
Eki 27 11:27:45 IUCLap NetworkManager[572]: <info>  [1761553665.3314] device (wlan0): Activation: (wifi) connection 'eduroam' has security, and secrets exist.  No new secrets needed.
Eki 27 11:27:45 IUCLap NetworkManager[572]: <info>  [1761553665.3314] Config: added 'ssid' value 'eduroam'
Eki 27 11:28:10 IUCLap NetworkManager[572]: <warn>  [1761553690.1350] device (wlan0): Activation: failed for connection 'eduroam'
Eki 27 11:33:10 IUCLap NetworkManager[572]: <info>  [1761553990.1239] policy: auto-activating connection 'eduroam' (26d4b586-8d47-4fcc-a6e0-403809bfdfb8)
Eki 27 11:33:10 IUCLap NetworkManager[572]: <info>  [1761553990.1277] device (wlan0): Activation: starting connection 'eduroam' (26d4b586-8d47-4fcc-a6e0-403809bfdfb8)
Eki 27 11:33:10 IUCLap NetworkManager[572]: <info>  [1761553990.1429] device (wlan0): Activation: (wifi) access point 'eduroam' has security, but secrets are required.
Eki 27 11:33:10 IUCLap NetworkManager[572]: <info>  [1761553990.1523] device (wlan0): Activation: (wifi) connection 'eduroam' has security, and secrets exist.  No new secrets needed.
Eki 27 11:33:10 IUCLap NetworkManager[572]: <info>  [1761553990.1524] Config: added 'ssid' value 'eduroam'
Eki 27 11:35:35 IUCLap NetworkManager[572]: <warn>  [1761554135.1671] device (wlan0): Activation: failed for connection 'eduroam'
Network manager keeps saying me that secrets are wrong but they are not. With the same laptop I don’t have any problem connecting with debian distros like Ubuntu,Zorin os, Pop Os etc. but no connection with Arch based distros or fedora or anything other than Debian. So what might be the problem. I really like to use Arch so would you please help.
Thanks in advance
NB: By the way I tried to use wpa-supplicant to but no avail.
geteduroam is installed?
Typically, it should work right away. However, some institutions take the easy route and never update to modern standards. You might first contact your IT support to check if there are any hints or configuration settings that they requires.
If they flatout refuse supporting Linux, they might support Apple-devices, The configuration options are quite similar. Also, the Android settings might give a hint.
A last point might be that the credentials are actually wrong: some need the domain, some the email address or another have a username and now you’re locked out for a few minutes. (This happened to me after a password change: the phone tried to connect with the old password and I was blocked for half a day.)
If you mean about the python program from cat.eduroam.org. Yes I did. But no avail.
Mithrial:
1)I opened a ticket from IT support couldn’t help me.
2)Credentials: I am 1000% sure that the credentials arant wrong. They request the username with domain etc.
Actually with totally the same config and laptop under pop os or zorinos works flawlessly.
It must be a configuration or driver issue under Arch Linux distros.
Thank you anyway
what is the result with a different kernel? e.g. longterm
That doesn’t change anything
ok
you wrote that you tried wpa-supplicant.
guess you did edit the config
Still could be old standards.
Yes I did, I’ve done a lot of things before writing here, I assure you, but any insight that I overlooked will be greatly appreciated
I did this too but my university uses PEAP as phase 1 so does it matter?
No one has the same outcome with my problem?
Interesting to not find a solution!
Yes, I have the same. It works under Ubuntu but not CachyOS…
I’m experiencing the same issue. Tried different proposed solutions but nothing seems to work for me.
I solved this on my machine by changing the authentication type from PEAP to TTLS.
