Dota 2 Issues on Linux - ONLY Dota 2 - Help!
Hey everyone, I’m having a really frustrating issue with Dota 2 on my CachyOS system, and it’s only Dota 2 that’s giving me problems. Other games, including CS2 (native) and Watch Dogs Legion (via Proton), run perfectly fine.
There are lags/stutters which completely skip some frames and then continues please refer this video (0:19) & (1:19) time stamps for stutters
Here’s what I’ve tried:
  1. Driver Swap: Switched from open-source NVIDIA drivers to closed-source NVIDIA drivers (currently on 565.77).
  2. Vsync Shenanigans: Tried enabling and disabling Vsync. No dice.
  3. Kernel Hopping: Moved from the standard cachyos kernel to cachyos-eevdf-lto. Still the same problem.
  4. Shader Compilation: Enabled and disabled shader pre-caching/compilation. Nada.
  5. Launch Options: Launched the game with no launch options at all. Nope.
  6. SSD Musical Chairs: Moved the game installation between two different SSDs. Still broken.
My System Specs:
KDE Plasma Version: 6.2.5
KDE Frameworks Version: 6.10.0
Qt Version: 6.8.1
Kernel Version: 6.12.9-1-cachyos-eevdf-lto (64-bit)
Graphics Platform: Wayland
Processors: 28 × Intel® Core™ i7-14700K
Memory: 31.1 GiB of RAM
Graphics Processor: NVIDIA GeForce RTX 4070 Ti/PCIe/SSE2
Manufacturer: Gigabyte Technology Co., Ltd.
Product Name: Z790 UD AC
❯ inxi -xxACGS
System:
  Host: io Kernel: 6.12.9-1-cachyos-eevdf-lto arch: x86_64 bits: 64
    compiler: clang v: 18.1.8
  Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
    Distro: CachyOS base: Arch Linux
CPU:
  Info: 20-core (8-mt/12-st) model: Intel Core i7-14700K bits: 64
    type: MST AMCP arch: Raptor Lake rev: 1 cache: L1: 1.8 MiB L2: 28 MiB
    L3: 33 MiB
  Speed (MHz): avg: 903 min/max: 800/5500:5600:4300 cores: 1: 903 2: 903
    3: 903 4: 903 5: 903 6: 903 7: 903 8: 903 9: 903 10: 903 11: 903 12: 903
    13: 903 14: 903 15: 903 16: 903 17: 903 18: 903 19: 903 20: 903 21: 903
    22: 903 23: 903 24: 903 25: 903 26: 903 27: 903 28: 903 bogomips: 191385
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
  Device-1: Intel Raptor Lake-S GT1 [UHD Graphics 770] vendor: Gigabyte
    driver: i915 v: kernel arch: Xe ports: active: none
    empty: DP-4,HDMI-A-2,HDMI-A-3 bus-ID: 00:02.0 chip-ID: 8086:a780
  Device-2: NVIDIA AD104 [GeForce RTX 4070 Ti] vendor: Gigabyte
    driver: nvidia v: 565.77 arch: Lovelace pcie: speed: 16 GT/s lanes: 16
    ports: active: none off: DP-2,HDMI-A-1 empty: DP-1,DP-3 bus-ID: 01:00.0
    chip-ID: 10de:2782
  Device-3: Lenovo FHD Webcam driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 1-6.1:5 chip-ID: 17ef:4831
  Display: wayland server: X.org v: 1.21.1.15 with: Xwayland v: 24.1.4
    compositor: kwin_wayland driver: gpu: nvidia,nvidia-nvswitch
    d-rect: 4480x2520 display-ID: 0
  Monitor-1: DP-2 pos: primary,top-left model: LG (GoldStar) ULTRAGEAR
    res: 2560x1440 hz: 144 dpi: 109 diag: 685mm (27")
  Monitor-2: HDMI-A-1 pos: bottom-r model: LG (GoldStar) IPS FULLHD
    res: 1920x1080 hz: 60 dpi: 102 diag: 551mm (21.7")
  API: EGL v: 1.5 platforms: device: 0 drv: nvidia gbm: drv: nvidia
    surfaceless: drv: nvidia wayland: drv: nvidia x11: drv: nvidia
  API: OpenGL v: 4.6.0 vendor: nvidia v: 565.77 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce RTX 4070 Ti/PCIe/SSE2
    display-ID: :0.0
  API: Vulkan v: 1.4.303 surfaces: xcb,xlib,wayland device: 0
    type: discrete-gpu driver: N/A device-ID: 10de:2782 device: 1
    type: integrated-gpu driver: N/A device-ID: 8086:a780
    de: kscreen-console,kscreen-doctor gpu: nvidia-settings,nvidia-smi
    wl: wayland-info x11: xdpyinfo, xprop, xrandr
Audio:
  Device-1: Intel Raptor Lake High Definition Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:7a50
  Device-2: NVIDIA AD104 High Definition Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 16
    bus-ID: 01:00.1 chip-ID: 10de:22bc
  API: ALSA v: k6.12.9-1-cachyos-eevdf-lto status: kernel-api
  Server-1: JACK v: 1.9.22 status: off
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
As you can see, I’ve got a pretty beefy system, so I don’t think it’s a hardware limitation. I’m at my wit’s end here. Any ideas what else I could try? Has anyone else experienced this specific issue with Dota 2 on Linux? Any help would be greatly appreciated!
TL;DR: Dota 2 is broken on my CachyOS system, other games work fine. Tried a bunch of stuff, no luck. Help!
Did you try a different compatibility layer? Sometimes the newer Protons have regressions that 8.0 doesn’t have.
Dota2 is a Native game to linux and doesnt support to be played via proton
haha, forgot about that. Probably some unfixable NVIDIA thing then.
Try both steam and steam-native. If that doesn’t work, start steam from the terminal and post the output.
both had issues steam-native and steam-runtime this is the output of me running steam
❯ steam
steam.sh[1210878]: Running Steam on cachyos rolling 64-bit
steam.sh[1210878]: STEAM_RUNTIME is enabled automatically
setup.sh[1210928]: Steam runtime environment up-to-date!
steam.sh[1210878]: Steam client's requirements are satisfied
CProcessEnvironmentManager is ready, 6 preallocated environment variables.
[2025-01-19 01:48:20] Startup - updater built Dec  2 2024 21:26:10
[2025-01-19 01:48:20] Startup - Steam Client launched with: '/home/xzat/.local/share/Steam/ubuntu12_32/steam' '-srt-logger-opened'
01/19 01:48:20 minidumps folder is set to /tmp/dumps
01/19 01:48:20 Init: Installing breakpad exception handler for appid(steam)/version(1733265492)/tid(1211013)
[2025-01-19 01:48:20] Loading cached metrics from disk (/home/xzat/.local/share/Steam/package/steam_client_metrics.bin)
[2025-01-19 01:48:20] Using the following download hosts for Public, Realm steamglobal
[2025-01-19 01:48:20] 1. https://client-update.fastly.steamstatic.com, /, Realm 'steamglobal', weight was 900, source = 'update_hosts_cached.vdf'
[2025-01-19 01:48:20] 2. https://client-update.akamai.steamstatic.com, /, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2025-01-19 01:48:20] 3. https://client-update.steamstatic.com, /, Realm 'steamglobal', weight was 1, source = 'baked in'
[2025-01-19 01:48:20] Verifying installation...
[2025-01-19 01:48:20] Verification complete
UpdateUI: skip show logo
Steam logging initialized: directory: /home/xzat/.local/share/Steam/logs
XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xee886dc0
XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xee885500
steamwebhelper.sh[1211020]: Using supervisor /home/xzat/.steam/root/ubuntu12_32/steam-runtime/amd64/usr/bin/steam-runtime-supervisor
steamwebhelper.sh[1211020]: Starting steamwebhelper under bootstrap sniper steam runtime via /home/xzat/.local/share/Steam/ubuntu12_64/steam-runtime-sniper.sh
steamwebhelper.sh[1211020]: Using CEF sandbox \(try with -no-cef-sandbox if this fails\)
steamwebhelper.sh[1211020]: Starting steamwebhelper with Sniper steam runtime at /home/xzat/.local/share/Steam/ubuntu12_64/steam-runtime-sniper/_v2-entry-point
exec ./steamwebhelper -lang=en_US -cachedir=/home/xzat/.local/share/Steam/config/htmlcache -steampid=1211013 -buildid=1733265492 -steamid=0 -logdir=/home/xzat/.local/share/Steam/logs -uimode=7 -startcount=0 -steamuniverse=Public -realm=Global -clientui=/home/xzat/.local/share/Steam/clientui -steampath=/home/xzat/.local/share/Steam/ubuntu12_32/steam -launcher=0 -use_xcomposite_workaround -no-restart-on-ui-mode-change --valve-initial-threadpool-size=16 --valve-enable-site-isolation --enable-smooth-scrolling --disable-gpu-compositing --disable-gpu --password-store=basic --log-file=/home/xzat/.local/share/Steam/logs/cef_log.txt --disable-quick-menu --disable-features=SpareRendererForSitePerProcess,DcheckIsFatal,ValveFFmpegAllowLowDelayHEVC
Steam Runtime Launch Service: starting steam-runtime-launcher-service
Steam Runtime Launch Service: steam-runtime-launcher-service is running pid 1211212
bus_name=com.steampowered.PressureVessel.LaunchAlongsideSteam
/home/xzat/.themes/Juno-ocean-v40/gtk-2.0/main.rc:729: error: unexpected identifier 'direction', expected character '}'
/home/xzat/.themes/Juno-ocean-v40/gtk-2.0/apps/chrome.rc:50: error: invalid string constant "button", expected valid string constant
/home/xzat/.themes/Juno-ocean-v40/gtk-2.0/apps/xfce.rc:79: error: invalid string constant "entry", expected valid string constant
fsync: up and running.
Desktop state changed: desktop: { pos:    0,   0 size: 4480,1440 } primary: { pos:    0,   0 size: 2560,1440 }
Caching cursor image for left_ptr, size 32x32, serial 2, cache size = 0
BuildCompleteAppOverviewChange: 256 apps
Fossilize INFO: Setting autogroup scheduling.
Fossilize INFO: Overriding serialization path: "/home/xzat/.local/share/Steam/shader_cache_temp_dir_d3d11_64/fozpipelinesv6/steamapprun_pipeline_cache".
Fossilize INFO: Overriding serialization path: "/home/xzat/.local/share/Steam/shader_cache_temp_dir_d3d12_64/fozpipelinesv6/steamapprun_pipeline_cache".
did you start dota 2?
na i thought without dota2
here is with launched dota 2 and played in demo
❯ steam
steam.sh[225653]: Running Steam on cachyos rolling 64-bit
steam.sh[225653]: STEAM_RUNTIME is enabled automatically
setup.sh[225703]: Steam runtime environment up-to-date!
steam.sh[225653]: Steam client's requirements are satisfied
[2025-01-19 22:39:26] Startup - updater built Dec  2 2024 21:26:10
[2025-01-19 22:39:26] Startup - Steam Client launched with: '/home/xzat/.local/share/Steam/ubuntu12_32/steam' '-srt-logger-opened'
01/19 22:39:26 minidumps folder is set to /tmp/dumps
01/19 22:39:26 Init: Installing breakpad exception handler for appid(steam)/version(1733265492)/tid(225761)
[2025-01-19 22:39:26] Loading cached metrics from disk (/home/xzat/.local/share/Steam/package/steam_client_metrics.bin)
[2025-01-19 22:39:26] Using the following download hosts for Public, Realm steamglobal
[2025-01-19 22:39:26] 1. https://client-update.fastly.steamstatic.com, /, Realm 'steamglobal', weight was 900, source = 'update_hosts_cached.vdf'
[2025-01-19 22:39:26] 2. https://client-update.akamai.steamstatic.com, /, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2025-01-19 22:39:26] 3. https://client-update.steamstatic.com, /, Realm 'steamglobal', weight was 1, source = 'baked in'
[2025-01-19 22:39:26] Verifying installation...
[2025-01-19 22:39:26] Verification complete
XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xef063dc0
XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xef062500
steamwebhelper.sh[225784]: Using supervisor /home/xzat/.steam/root/ubuntu12_32/steam-runtime/amd64/usr/bin/steam-runtime-supervisor
steamwebhelper.sh[225784]: Starting steamwebhelper under bootstrap sniper steam runtime via /home/xzat/.local/share/Steam/ubuntu12_64/steam-runtime-sniper.sh
steamwebhelper.sh[225784]: Using CEF sandbox \(try with -no-cef-sandbox if this fails\)
steamwebhelper.sh[225784]: Starting steamwebhelper with Sniper steam runtime at /home/xzat/.local/share/Steam/ubuntu12_64/steam-runtime-sniper/_v2-entry-point
exec ./steamwebhelper -lang=en_US -cachedir=/home/xzat/.local/share/Steam/config/htmlcache -steampid=225761 -buildid=1733265492 -steamid=0 -logdir=/home/xzat/.local/share/Steam/logs -uimode=7 -startcount=0 -steamuniverse=Public -realm=Global -clientui=/home/xzat/.local/share/Steam/clientui -steampath=/home/xzat/.local/share/Steam/ubuntu12_32/steam -launcher=0 -use_xcomposite_workaround -no-restart-on-ui-mode-change --valve-initial-threadpool-size=16 --valve-enable-site-isolation --enable-smooth-scrolling --disable-gpu-compositing --disable-gpu --password-store=basic --log-file=/home/xzat/.local/share/Steam/logs/cef_log.txt --disable-quick-menu --disable-features=SpareRendererForSitePerProcess,DcheckIsFatal,ValveFFmpegAllowLowDelayHEVC
Steam Runtime Launch Service: steam-runtime-launcher-service is running pid 226039
Caching cursor image for left_ptr, size 32x32, serial 3, cache size = 0
chdir "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta"
Game Recording - would start recording game 570, but recording for this game is disabled
Adding process 227756 for gameID 570
ERROR: ld.so: object '/home/xzat/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
Adding process 227772 for gameID 570
Adding process 227771 for gameID 570
pid 227835 != 227833, skipping destruction (fork without exec?)
Adding process 227790 for gameID 570
Adding process 227808 for gameID 570
Adding process 227833 for gameID 570
Adding process 227836 for gameID 570
basename: extra operand 'beta/game/dota.sh'
Try 'basename --help' for more information.
Loaded /home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/bin/linuxsteamrt64/libengine2.so, got 0x63afe8732450
Using breakpad crash handler
[S_API] SteamAPI_Init(): Loaded '/home/xzat/.local/share/Steam/linux64/steamclient.so' OK.
Setting breakpad minidump AppID = 570
Forcing breakpad minidump interfaces to load
Looking up breakpad interfaces from steamclient
Calling BreakpadMiniDumpSystemInit
01/19 22:39:43 minidumps folder is set to /tmp/dumps
01/19 22:39:43 Init: Installing breakpad exception handler for appid(570)/version(9465776)/tid(228079)
SteamInternal_SetMinidumpSteamID:  Caching Steam ID:  76561198816335978 [API loaded yes]
SteamInternal_SetMinidumpSteamID:  Setting Steam ID:  76561198816335978
Setting breakpad minidump AppID = 373300
Loaded libSDL3.so.0, got 0x63afe8858320
Loaded /home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/bin/linuxsteamrt64/libtier0.so, got 0x63afe8711130
Loaded /home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/bin/linuxsteamrt64/libfilesystem_stdio.so, got 0x63afe88a6660
Loaded /home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/bin/linuxsteamrt64/libinputsystem.so, got 0x63afe88ac2d0
Loaded /home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/bin/linuxsteamrt64/liblocalize.so, got 0x63afe88ad770
Loaded /home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/bin/linuxsteamrt64/librendersystemvulkan.so, got 0x63afe88addd0
Loaded /home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/bin/linuxsteamrt64/libresourcesystem.so, got 0x63afe8914df0
Loaded /home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/bin/linuxsteamrt64/libschemasystem.so, got 0x63afe8927860
Fossilize INFO: Overriding serialization path: "/home/xzat/storage-drive/SteamLibrary/steamapps/shadercache/570/fozpipelinesv6/steamapprun_pipeline_cache".
Loaded /home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/bin/linuxsteamrt64/libmaterialsystem2.so, got 0x63affd877020
Loaded libpangoft2-1.0.so, got (nil)
 failed to dlopen "libpangoft2-1.0.so" error=libpangoft2-1.0.so: cannot open shared object file: No such file or directory
Loaded /home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/bin/linuxsteamrt64/libpanorama_text_pango.so, got 0x63affd8a5280
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 38: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 39: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 40: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 41: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 42: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 43: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 44: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 45: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 46: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 47: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 48: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 49: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 50: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 51: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 52: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 53: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 54: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 55: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 56: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 57: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 58: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 59: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 60: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 61: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 62: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 63: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 64: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 65: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 66: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 67: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 68: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 69: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 70: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 71: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 72: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 73: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 74: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 75: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 76: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 77: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 78: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 79: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 80: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 81: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 82: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 83: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 84: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 85: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 86: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 87: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 88: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 89: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 90: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 91: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 92: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 93: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 94: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 95: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 96: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 97: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 98: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 99: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 100: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 101: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 102: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 103: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 104: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 105: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 106: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 107: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 108: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 109: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 110: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 111: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 112: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 113: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 114: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 115: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 116: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 117: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/fonts.conf", line 118: unknown element "fontpattern"
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/conf.d/41-repl-os-win.conf", line 148: Having multiple values in <test> isn't supported and may not work as expected
Fontconfig warning: "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/core/panorama/fonts/conf.d/41-repl-os-win.conf", line 160: Having multiple values in <test> isn't supported and may not work as expected
Loaded libfreetype.so.6, got 0x63affd8a6960
Loaded libfontconfig.so.1, got 0x63affd8a6f60
[2025-01-19 22:39:44.818] [MANGOHUD] [error] [nvctrl.cpp:56] XNVCtrl didn't find the correct display
Loaded /home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/bin/linuxsteamrt64/libmeshsystem.so, got 0x63affd99ca40
Loaded /home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/bin/linuxsteamrt64/libworldrenderer.so, got 0x63affd9aec80
Loaded /home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/bin/linuxsteamrt64/libpulse_system.so, got 0x63affd9c1760
Loaded /home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/bin/linuxsteamrt64/libvscript.so, got 0x63affd9d6970
Loaded /home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/bin/linuxsteamrt64/libnetworksystem.so, got 0x63affd9e8c00
Loaded /home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/bin/linuxsteamrt64/libanimationsystem.so, got 0x63affd9fd4f0
Loaded /home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/bin/linuxsteamrt64/libvphysics2.so, got 0x63affda13a70
Loaded /home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/bin/linuxsteamrt64/libsoundsystem.so, got 0x63affda26b30
Loaded /home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/bin/linuxsteamrt64/libscenesystem.so, got 0x63affda3d8d0
Loaded /home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/bin/linuxsteamrt64/libparticles.so, got 0x63affda536e0
Loaded /home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/bin/linuxsteamrt64/libv8system.so, got 0x63affda66c20
Loaded /home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/dota/bin/linuxsteamrt64/libserver.so, got 0x63affec792d0
Loaded /home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/dota/bin/linuxsteamrt64/libclient.so, got 0x63affeccbeb0
Loaded /home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/bin/linuxsteamrt64/libpanorama.so, got 0x63affe9cab10
Loaded libmpg123.so.0, got 0x63affc3bfca0
Loaded /home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/bin/linuxsteamrt64/libcairo.so, got 0x63affdcc0920
Loaded /home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/dota/bin/linuxsteamrt64/libhost.so, got 0x63affe124130
Loaded /home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/bin/linuxsteamrt64/libscenefilecache.so, got 0x63affe125b20
warning: The VAD has been replaced by a hack pending a complete rewrite
IPC function call IClientAudio::StartVoiceRecording took too long: 54 msec
Loaded /home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/bin/linuxsteamrt64/librenderdoc.so, got (nil)
 failed to dlopen "/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/bin/linuxsteamrt64/librenderdoc.so" error=/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/bin/linuxsteamrt64/librenderdoc.so: cannot open shared object file: No such file or directory
Loaded librenderdoc.so, got (nil)
 failed to dlopen "librenderdoc.so" error=librenderdoc.so: cannot open shared object file: No such file or directory
SteamInternal_SetMinidumpSteamID:  Caching Steam ID:  76561197960265728 [API loaded yes]
SteamInternal_SetMinidumpSteamID:  Setting Steam ID:  76561197960265728
[2025-01-19 22:41:27] Background update loop checking for update. . .
[2025-01-19 22:41:27] Checking for available updates...
[2025-01-19 22:41:27] Downloading manifest: https://client-update.fastly.steamstatic.com/steam_client_ubuntu12
[2025-01-19 22:41:27] Manifest download: send request
[2025-01-19 22:41:27] Manifest download: waiting for download to finish
[2025-01-19 22:41:27] Manifest download: finished
[2025-01-19 22:41:27] Download skipped: /steam_client_ubuntu12 version 1733265492, installed version 1733265492, existing pending version 0
[2025-01-19 22:41:27] Nothing to do
Warning: failed to set thread priority: set failed for -10: 1:
[S_API FAIL] Tried to access Steam interface STEAMCHAT_INTERFACE_VERSION003 before SteamAPI_Init succeeded.
CSteam3Client::Shutdown
crash_20250119224310_17.dmp[258496]: Uploading dump (out-of-process)
/tmp/dumps/crash_20250119224310_17.dmp
crash_20250119224310_17.dmp[258496]: Finished uploading minidump (out-of-process): success = no
crash_20250119224310_17.dmp[258496]: error: Couldn't connect to server
crash_20250119224310_17.dmp[258496]: file ''/tmp/dumps/crash_20250119224310_17.dmp'', upload no: ''Couldn't connect to server''
/home/xzat/storage-drive/SteamLibrary/steamapps/common/dota 2 beta/game/dota.sh: line 113: 228079 Segmentation fault      (core dumped) ${STEAM_RUNTIME_PREFIX} ${GAME_DEBUGGER} "${GAMEROOT}"/${GAMEEXE} "$@"
Game Recording - game stopped [gameid=570]
Removing process 227836 for gameID 570
Removing process 227833 for gameID 570
Removing process 227808 for gameID 570
Removing process 227790 for gameID 570
Removing process 227771 for gameID 570
Removing process 227772 for gameID 570
Removing process 227756 for gameID 570
