I’m having a problem with setting the resolution of one of my monitors on a fresh install. I have a nvidia GTX 1080 and the problem happens when the monitor is connected to either HDMI or DisplayPort outputs (DVI works fine). The monitor in question shows as ‘DP-2-unknown’ or ‘HDMI-2-unknown’ depending on which output it’s connected to. The only available resolutions are 1024x768 and down. The exact same setup works fine on Windows 10.
I’ve tried downgrading my drivers as described in various places. I followed the instructions here: https://www.reddit.com/r/archlinux/comments/1osj2u7/i_cant_set_my_display_to_the_correct_resolution/ without anything seeming to change.
I’ve tried using xrandr, the result of ‘xrandr –newmode’ is ‘Error of failed request: BadName (named color or font does not exist)’. So far as I can tell I carried it out correctly.
Bug report: c3b72f1
I’m sure I’m missing something obvious or that I made a mistake somewhere.
I’d be grateful for any help.
