Davinci Resolve issues
Davinci resolve keeps telling me my GPU memory is full. I have rtx 3050ti laptop and I have never had this problem in any other distro I have tried except cachyos. It even used to work in windows 11. I tried running resolve with prime but nothing changes. I changed GPU mode from cuda to opencl and now I can’t even play videos or hear audio at all. I don’t know what the problem is and I can’t even find anything helpful online
Not sure if this will help or not
DaVinci Resolve 19 - Your GPU memory is full
I ran into this when DR updated to 19, and this helped me on my end.
  • Reduce Timeline Resolution : Lowering the timeline resolution can reduce the amount of VRAM used by DaVinci Resolve. You can do this by going to Project Settings > Master Settings > Timeline Resolution and selecting a lower resolution like 1920 x 1080 HD.
nvidia-smi|grep -e Driver -e Cuda
| NVIDIA-SMI 570.133.07             Driver Version: 570.133.07     CUDA Version: 12.8     |
top -b -n 1 | grep -e GUI -e resolve
  53601 me        29   9   24.4g   1.8g 636964 S  17.9  13.4   1:56.03 GUI Thr+
uh oh, memory leak, my worst enemy. I don’t think there’s even a fix that so I am guess I am just gonna use something else. Thank you, this helped me figure out the problem at least
I tried to set it as low as possible but it literally doesn’t do anything lmao
Sorry to heart that, but it seems to be fine not super just Ok, on my end
Graphics:
  Device-1: NVIDIA GA107BM [GeForce RTX 3050 Ti Mobile] vendor: Lenovo
    driver: nvidia v: 570.133.07 alternate: nouveau,nvidia_drm
    non-free: 550/565.xx+ status: current (as of 2025-01; EOL~2026-12-xx)
    arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie:
    gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
    ports: active: none empty: DP-1, DP-2, HDMI-A-1, eDP-1 bus-ID: 01:00.0
    chip-ID: 10de:25e0 class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
    Radeon Mobile Series] vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
    code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s
    lanes: 16 ports: active: eDP-2 empty: none bus-ID: 06:00.0
    chip-ID: 1002:1638 class-ID: 0300 temp: 36.0 C
  Device-3: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 5986:2137
    class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6
    compositor: gnome-shell v: 48.1 driver: X: loaded: amdgpu
    unloaded: modesetting alternate: fbdev,vesa dri: radeonsi gpu: amdgpu
    display-ID: 0
Hey there, I also have this issue and I’ve tried these solutions and they didn’t work. I’m using an RTX 2050 laptop and when switching to CachyOS this happened.
