CS2 Segmentation Fault on RTX 4060 Ti - libnvidia-gpucomp.so / libmatchmaking.so
Hello CachyOS community,
I’m experiencing consistent crashes with Counter-Strike 2. The game fails to launch, resulting in a Segmentation Fault right after loading libmatchmaking.so.
My Specs:
  • GPU: NVIDIA RTX 4060 Ti
  • Kernel: 6.18.x-LTS (also tried 7.0.x-cachyos)
  • Driver: Tried 595.71.05 and downgraded to 580.119.02
  • DE/WM: Hyprland (Wayland)
Symptoms:
  1. In some cases, GPU fans spin up to 100% (GPU Reset) before the crash.
  2. Journalctl shows segfault in libnvidia-gpucomp.so.
  3. Steam logs show Segmentation fault (core dumped) after libmatchmaking.so is loaded.
What I’ve tried:
  • Verified game files.
  • Cleared ~/.nv/GLCache and shadercache/730.
  • Launch options: -vulkan +r_disable_async_pipeline_state_compiler 1 __GL_SHADER_DISK_CACHE=0.
  • Symlinked libpangoft2-1.0.so.0 to libpangoft2-1.0.so in game directory.
  • Tried SRT_USE_HOST_LIBRARIES=1.
Logs attached: 6173f21
Is this a known issue with the current NVIDIA userspace libraries in the v3/v4 repositories? Any advice on how to bypass this gpucomp segfault?
