I’m running into an issue where I have crackling noise in Steam. There is a launch command that does help but I have to put this in for every game that I play. I was wondering if there was a more permanent fix for this.
Steam Launch command that works
PULSE_LATENCY_MSEC=50 %command%
System Info
System:
Kernel: 6.12.8-2-cachyos arch: x86_64 bits: 64 compiler: clang v: 18.1.8
Desktop: KDE Plasma v: 6.2.5 Distro: CachyOS base: Arch Linux
Machine:
Type: Laptop System: Micro-Star product: Stealth 16 AI Studio A1VHG
v: REV:1.0 serial: <superuser required>
Mobo: Micro-Star model: MS-15F3 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: E15F3IMS.10C date: 10/14/2024
Battery:
ID-1: BAT1 charge: 93.1 Wh (97.7%) condition: 95.3/95.0 Wh (100.3%)
volts: 17.1 min: 15.2 model: MSI BIF0_9 status: not charging
Device-1: hidpp_battery_8 model: Logitech MX Master 3S charge: 95%
status: discharging
CPU:
Info: 16-core (6-mt/10-st) model: Intel Core Ultra 9 185H bits: 64
type: MST AMCP arch: Meteor Lake rev: 4 cache: L1: 1.6 MiB L2: 18 MiB
L3: 24 MiB
Speed (MHz): avg: 400 min/max: 400/4800:5100:3800:2500 cores: 1: 400
2: 400 3: 400 4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400
12: 400 13: 400 14: 400 15: 400 16: 400 17: 400 18: 400 19: 400 20: 400
21: 400 22: 400 bogomips: 135168
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
Device-1: Intel Meteor Lake-P [Intel Arc Graphics] vendor: Micro-Star MSI
driver: i915 v: kernel arch: Gen-13 bus-ID: 0000:00:02.0
Device-2: NVIDIA AD104M [GeForce RTX 4080 Max-Q / Mobile]
vendor: Micro-Star MSI driver: nvidia v: 565.77 arch: Lovelace
bus-ID: 0000:01:00.0
Device-3: Bison FHD Camera driver: uvcvideo type: USB bus-ID: 3-9:4
Display: wayland server: X.org v: 1.21.1.15 with: Xwayland v: 24.1.4
compositor: kwin_wayland driver: N/A resolution: 1707x1067
API: EGL v: 1.5 drivers: iris,nvidia platforms:
active: gbm,wayland,x11,surfaceless,device inactive: N/A
API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: intel mesa v: 24.3.3-cachyos1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Arc Graphics (MTL)
API: Vulkan v: 1.4.303 drivers: N/A surfaces: xcb,xlib,wayland devices: 2
Audio:
Device-1: Intel Meteor Lake-P HD Audio vendor: Micro-Star MSI
driver: sof-audio-pci-intel-mtl bus-ID: 0000:00:1f.3
Device-2: NVIDIA AD104 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1
Device-3: Razer USA BlackShark V2 Pro
driver: hid-generic,snd-usb-audio,usbhid type: USB bus-ID: 3-5:12
API: ALSA v: k6.12.8-2-cachyos status: kernel-api
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 1.2.7 status: active
Network:
Device-1: Intel Wi-Fi 7 AX1775 /AX1790 /BE20 /BE401/BE1750 2x2
vendor: Rivet Networks driver: iwlwifi v: kernel bus-ID: 0000:2c:00.0
IF: wlan0 state: up mac: <filter>
Device-2: Realtek Killer E3000 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel port: 3000 bus-ID: 0000:2d:00.0
IF: enp45s0 state: down mac: <filter>
Bluetooth:
Device-1: Intel driver: btusb v: 0.8 type: USB bus-ID: 3-10:5
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.4
lmp-v: 13
RAID:
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 bus-ID: 0000:00:0e.0
Drives:
Local Storage: total: 2.75 TiB used: 484.33 GiB (17.2%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVL21T0HDLU-00BT7
size: 953.87 GiB temp: 50.9 C
ID-2: /dev/nvme1n1 vendor: Sabrent model: Rocket 4.0 2TB size: 1.82 TiB
temp: 52.9 C
Partition:
ID-1: / size: 1.82 TiB used: 483.83 GiB (26.0%) fs: btrfs dev: /dev/dm-0
mapped: luks-b75d334b-20e4-4db4-be3a-e5317b37e812
ID-2: /boot size: 2 GiB used: 515.8 MiB (25.2%) fs: vfat
dev: /dev/nvme1n1p1
ID-3: /home size: 1.82 TiB used: 483.83 GiB (26.0%) fs: btrfs
dev: /dev/dm-0 mapped: luks-b75d334b-20e4-4db4-be3a-e5317b37e812
ID-4: /var/log size: 1.82 TiB used: 483.83 GiB (26.0%) fs: btrfs
ID-5: /var/tmp size: 1.82 TiB used: 483.83 GiB (26.0%) fs: btrfs
Swap:
ID-1: swap-1 type: zram size: 62.28 GiB used: 1.82 GiB (2.9%)
dev: /dev/zram0
Sensors:
System Temperatures: cpu: 54.5 C mobo: N/A
Fan Speeds (rpm): N/A
Info:
Memory: total: 64 GiB available: 62.28 GiB used: 9.21 GiB (14.8%)
Processes: 464 Uptime: 3d 7h 18m Init: systemd
Packages: 1404 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Bash v: 5.2.37
inxi: 3.3.36
