CPU power management issue
Here are the specifications of my computer:
  • RAM: Corsair Vengeance RGB RT, DDR4, 32 GB (2 x 16 GB), 3600MHz, CL16
  • Motherboard: MSI MAG B550 TOMAHAWK MAX WIFI
  • Fans: be quiet! Light Wings LX 140mm PWM High-Speed (3x at the front, 1x at the back)
  • Processor: AMD Ryzen 7 5800X (Undervolted, running at a fixed 4400 MHz on 1.17500V)
  • Cooling: be quiet! Pure Loop 2 FX 240mm (Mounted at the top of the case)
  • SSD Heatsink: be quiet! M.2 MC1 Pro
  • Storage: Samsung 990 Pro 1 TB
  • Case: Kolink Citadel Mesh ARGB (Version that supports E-ATX motherboards)
  • PSU: MSI MPG A850G PCIE5 850W
  • GPU: Gigabyte GeForce RTX 4070 WindForce OC 12GB
After installing CachyOS with KDE, when I open “Power Management” from the taskbar, it says that it’s not available. There’s no slider to adjust the CPU performance mode. Adding amd_pstate=active to GRUB didn’t help.
How can I fix this?
can you check
cpupower frequency-info
sudo journalctl -b0 | grep 'amd'
@stephane
❯ cpupower frequency-info
analyzing CPU 13:
  driver: acpi-cpufreq
  CPUs which run at the same hardware frequency: 13
  CPUs which need to have their frequency coordinated by software: 13
  maximum transition latency:  Cannot determine or is not supported.
  hardware limits: 2.20 GHz - 4.40 GHz
  available frequency steps:  4.40 GHz, 2.80 GHz, 2.20 GHz
  available cpufreq governors: conservative ondemand userspace powersave performance schedutil
  current policy: frequency should be within 2.20 GHz and 4.40 GHz.
                  The governor "schedutil" may decide which speed to use
                  within this range.
  current CPU frequency: Unable to call hardware
  current CPU frequency: 4.40 GHz (asserted by call to kernel)
  boost state support:
    Supported: yes
    Active: no
❯ sudo journalctl -b0 | grep 'amd'
sty 11 18:18:39 pc kernel: Command line: BOOT_IMAGE=/@/boot/vmlinuz-linux-cachyos root=UUID=2c80824f-5e5b-4991-8a12-f81b0ab5f927 rw rootflags=subvol=@ nowatchdog nvme_load=YES zswap.enabled=0 splash loglevel=3 amd_pstate=active
sty 11 18:18:39 pc kernel: Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-linux-cachyos root=UUID=2c80824f-5e5b-4991-8a12-f81b0ab5f927 rw rootflags=subvol=@ nowatchdog nvme_load=YES zswap.enabled=0 splash loglevel=3 amd_pstate=active
sty 11 18:18:39 pc kernel: perf/amd_iommu: Detected AMD IOMMU #0 (2 banks, 4 counters/bank).
sty 11 18:18:39 pc kernel: amd_pstate: the _CPC object is not present in SBIOS or ACPI disabled
sty 11 18:18:40 pc kernel: kvm_amd: TSC scaling supported
sty 11 18:18:40 pc kernel: kvm_amd: Nested Virtualization enabled
sty 11 18:18:40 pc kernel: kvm_amd: Nested Paging enabled
sty 11 18:18:40 pc kernel: kvm_amd: LBR virtualization supported
sty 11 18:18:40 pc kernel: kvm_amd: Virtual VMLOAD VMSAVE supported
sty 11 18:18:40 pc kernel: kvm_amd: Virtual GIF supported
sty 11 18:18:40 pc kernel: amd_atl: AMD Address Translation Library initialized
is cppc active in your UEFI motherboard ( advanced cpu )?
I have this option in UEFI, but I turned off CPPC.
@stephane
I enabled CPPC in the UEFI, and the problem was resolved. Thank you for your help!!
in this case , amd-pstate or amd-pstate-epp cant be used , it failback to acpi-cpufreq.
takes all info screen for your cpu ( Volt , etc , ) , because if your active cppc , it may changes others values
from mine
analyse du CPU 9 :
  driver: amd-pstate-epp
  CPUs which run at the same hardware frequency: 9
  CPUs which need to have their frequency coordinated by software: 9
  limitation matérielle : 550 MHz - 4.65 GHz
  régulateurs disponibles : performance powersave
  tactique actuelle : la fréquence doit ÃÂȘtre comprise entre 550 MHz et 4.65 GHz.
                  Le régulateur "performance" est libre de choisir la vitesse
                  dans cette plage de fréquences.
  current CPU frequency: 550 MHz (asserted by call to kernel)
    Supported: yes
    Active: yes
    AMD PSTATE Highest Performance: 176. Maximum Frequency: 4.65 GHz.
    AMD PSTATE Nominal Performance: 132. Nominal Frequency: 3.70 GHz.
    AMD PSTATE Lowest Non-linear Performance: 62. Lowest Non-linear Frequency: 1.73 GHz.
    AMD PSTATE Lowest Performance: 20. Lowest Frequency: 550 MHz.
in amd-pstate-epp be careful there is value power and cpu scheduler
you have only powersave or performance
if you want amd-pstate=passive or active you need to put this parameter to boot kernel
you have these options
in both case frequency cpu can varying from 400ghz to max 4,65ghz
