hi
trwtied to build systemd
, but it didn’t want, because missing libLLVM.so.19.1
--- stderr ---
/usr/bin/clang: error while loading shared libraries: libLLVM.so.19.1: cannot open shared object file: No such file or directory
systemd/meson.build:1099:28: ERROR: Command `/usr/bin/clang --version` failed with status 127.
but it should be persent
tom@cachyos ~/compile/systemd # pacman -F libLLVM.so.19.1
cachyos-v4/llvm-libs 19.1.6-4 [installed: 18.1.8-7]
usr/lib/libLLVM.so.19.1
extra/llvm-libs 19.1.6-3 [installed: 18.1.8-7]
multilib/lib32-llvm-libs 1:19.1.6-1 [installed]
