Generally, I understand this article. But CachyOS is simply not done for the hardware they have tested.
They are using a super old not supported nvidia cards.
ThinkPad W520
Not supported
NVIDIA Quadro 1000 GPU
Also not supported
Complaining about too less packages installed
CachyOS comes barebones, that is intended to avoid bloat
We had to mount the CachyOS root partition for the Ubuntu version of GRUB’s os-prober to find it, but it wouldn’t boot, giving an error:
Maybe an issue of the Ubuntu bootloader? We have dozens of people, which are using OS PROPER on UEFI.
We are also not really want to support non UEFI systems, even tough we are still doing it. Maybe we should go the ciritical step and completly cut this people out, which is general something which we wanted to do since long time, but kept it for support of these old devices.
but most importantly adds openSUSE-style snapshot support and rollback
CachyOS has this too, simply a button in cachyos-hello does this
Despite downloading a just over 2.5 GB installation image, the installer won’t start until you make an internet connection because it always installs packages from the online repositories. For anyone on a metered internet connection, this is a very bad option. We feel the installer should offer you a choice, but it doesn’t.
This is explicitly intended. The requirements for for installing CachyOS are noted in the wiki, and that it requires a minimum of 50mbits. There is an offline installation available as fallback, but we do not support this.
However, we had repeated problems with installation failing to complete: Several times, but not only, at the final stage of installing the bootloader.
Using wrong partition schemes, because it seems they have installed “alongside” or “replace disk”. The parititon schemes of each bootloader can be also found in the wiki:
The installation media is slow to boot because it copies the live system into RAM, but even with 24 GB of memory, it doesn’t cache the package files.
What? This sentences does not really makes sense. Copying to RAM is slow → Slow USB Stick. Copying to RAM is only enabled for 8GB or higher configuration.
and why should it cache package files? Installing old packages does not make sense for an online installation
The installer was also unable to pick up an existing swap partition, even when pointed at it, and installed the ZRAM in-memory swap daemon instead.
Intended
Both UKUI and Cutefish consistently failed, with the window manager not starting
Cutefish has been removed, so it seems not using the latest ISO, see netinstall: packagechooser: Drop cutefish · CachyOS/cachyos-calamares@3857b81 · GitHub
UKUI I have made around 8 installations about this article, with different VPN connections as well as on barebone and QEMU. No issues has been observed.
Just my comments so far. It seems that this writer did not made any basic research in terms of what is published in the wiki. This should be for a reviewer really a basic task. If they would have just read the minimum requirements, then 80% of these issues would be not existent.
I dont want to say that everything is perfect. Package Updates, Online Installation can cause issues - no question.
