CKB-Next not recognizing mouse?
Hey guys new to the OS, im trying to get my Corsair MMO mouse to pick up in the CKB-Next software but it is not…it is supported….says it is….but i have donie everything it says but its not being picked up in the app….any ideas? has anyone got it to work on CachyOS?
OR if anyone knows of any other software that allows me to tweak my corsair mouse/keyboard
Hello and welcome,
Can you describe more what you tried and what the outcome was?
There is ckb-next in the repositories.
ok so! I checked to see if my mouse was supported, it is:
1be3 SCIMITAR RGB ELITE Gaming Mouse
so i installed CKB i was asked to input these two commands into the konsole:
sudo systemctl start ckb-next-daemon
sudo systemctl enable ckb-next-daemon
then when the program started up full i get no detection no nothing just the settings page with No Devices connected.
that is where i am…i uninstalled it and reinstalled it multiple times nothing restarted pc multiple times nothing…
