when running sudo pacman -Syu, or using cachy-update, I get back
cachyos-znver4 is up to date
cachyos-core-znver4 is up to date
cachyos-extra-znver4 is up to date
cachyos is up to date
core is up to date
extra is up to date
multilib is up to date
error: failed retrieving file 'extra.db' from mirror.osbeck.com : The requested URL returned error: 404
error: could not open file /var/lib/pacman/sync/core.db: Unrecognized archive format
error: failed to prepare transaction (invalid or corrupted database)
This is happening on 2 desktops, since 2 days ago. Any ideas? Also, running the rank mirrors from cachy-hello seems to be doing nothing. rank mirrors been doing nothing for about 10 minutes now. Should I keep waiting???
If need be you can also share the configs and mirror list;
paste-cachyos /etc/pacman.conf
head -n -0 /etc/pacman.d/*mirrorlist | paste-cachyos
But I can also tell you that you can comment out (put a # in front of the line) of any problem mirrors like osbeck (though it should be working OK) in the /etc/pacman.d/*mirrorlist files.
Though none of this may fix the issue of
If necessary you may backup or delete the dbs there before retrying sync/refresh/upgrade (like with the bad mirrors commented out);
Having the same issue but I don’t know how to solve it since I am not using rank mirrors.
This is what I get
: Synchronizing package databases…
cachyos-v3 is up to date
cachyos-core-v3 is up to date
core is up to date
extra is up to date
error: could not open file /var/lib/pacman/sync/multilib.db: Unrecognized archive format
warning: libpng12: local (1.2.59-2.1) is newer than cachyos (1.2.59-2)
