I am trying to follow the UMU-Launcher guide from the Wiki but for some reason Lutris doesn’t show anything to select “/usr/bin/umu-run”
I already installed the umu-launcher package.
I m no gamer @yitzhak , but hope that link can be of any help to you, unless you already had a look at it;
https://www.reddit.com/r/Lutris/comments/o9358t/how_to_add_a_wine_version_on_lutris/
Thank you for the suggestions but unfortunately my issue is that the file picker to add the custom wine executable doesn’t show up for me like in this image from the wiki:
That sux @yitzhak , was that after an update or an install attempt to make shure.
Hopefully one in the know will chimin.
@itzhak :
That’s because you have to activate the advanced settings in general Wine options, then you’ll have advanced settings in each game conf/settings.
Now I feel dumb
Thank you very much @Ded4lus
You’re very welcome.
@altman : Thanks ^^
You re welcomed @Ded4lus
