Can anyone help me to build a kernel perfectly optimised to hardware I own using CachyOS Kernel manager?
My hardware
         .====++==============++++++++++*-                CPU: 13th Gen Intel(R) Core(TM) i9-13900K (32) @ 6.00 GHz
          .===+==================+++++++:                 GPU: NVIDIA GeForce RTX 4090 [Discrete]
           .-=======================+++:                  Memory: 4.35 GiB / 94.13 GiB (5%)
             ..........................                   Swap: 0 B / 94.13 GiB (0%)
                                                          Disk (/): 223.84 GiB / 1.82 TiB (12%) - xfs
These are the settings I tried, and the kernel manager successfully built it.
Thank you.
You should be just fine using the default kernels from the repo as they will take your hardware info and use it to build the kernel.
I guess only thing different on your build kernel is that it doesn’t use LTO
Thanks @altman and @inffy .
