For whatever reason, after the latest update, CachyOS will not start outside of LTS. I even attempted reinstalling the boot and root partitions (I have home on a separate one) and have the same issue. I cannot get to the TTY either, so I can’t debug it that way. The most I got was that some start task never moves forward. Tried it last night, had to shut it down after 19 hours of doing nothing. Is there any way I can fix this?
I just updated my system right after reading your post; no problems here at all; so I can’t reproduce your problem. I think the updates are okay coming from CachyOS, I’d guess it’s something within your system or some other thing.
- Try booting without any USB devices connected. Reconnect the devices after you get to a working desktop. Mouse and keyboard should work nearly instantly after being plugged into the working desktop. It could be a flash drive or any other USB devices holding things up.
On my linuxes, a USB SD card reader causes the whole system to hang forever if it’s connected during boot.
Questions:
Do you remember installing any custom kernels? (Linux kernel Version 7 is not yet fully ready, although the “release candidate” is already available for testing. I wouldn’t install it yet.)
Do you get to a GRUB> menu? or is there a flashing cursor on screen, or is the screen just blank?
On other distros I’ve tried, a blank screen usually means display mode / compatibility issues which are correctable if you can get into a GRUB menu during boot.
Have you tried booting into a Live USB linux? If that works, then at least you know that your hardware is (probably) working.
Do you remember any wierd errors or snafus during your original CachyOS install?
Sorry if I’m not helping yet, this is all I could come up with so far.
I have exactly the same problem. After this last update, my Cachyos machine in unusable. I can get past the Grub screen, I then hit enter to boot into Cachyos, and all I get is a black screen. The only USB device I have is my optical mouse. I will disconnect that and try again. Wish me luck.
You may use runlevels or similar even if you do not have an external to boot from;
From there you should be able to upgrade and/or even install other kernels.
ex;
sudo pacman -Syu linux-cachyos-lts
PS.
This is the kind of reason why keeping multiple kernels is a good idea.
Something like Latest+LatestLTS is a common reasonable combination.
I have LTS, though perhaps you are saying this for others? Good to know about the update command for it though.
I can get to systemd-boot’s menu. That’s how I open LTS. I have version 7 as my main kernel, so I assume that’s what’s borked it, though there are a few oddities that may suggest another issue. Using kernel 7 after rebooting without USB devices plugged in, I was able to get to the login screen and get to TTY from there. I was then able to get to the desktop using startplasma-wayland. I will try rebooting again to see if the problem has magically fixed itself. Booting into a live USB works fine. That’s how I was able to reinstall everything (should’ve tested LTS before doing this because now I’m stuck reinstalling all my programs but oh well. Doesn’t hurt to purge it every once in a while to get rid of programs I don’t use I suppose. I don’t recall any errors during my original CachyOS install, nor any others from before now that I wasn’t able to resolve.
Edit: Turns out removing USB devices does nothing to help. But what does help me get into kernel 7 is rebooting into LTS, then rebooting into the main kernel. This will get me to a login screen. Attempting to login normally leads to a black screen though, so I instead have to login through TTY. After logging in, I run startplasma-wayland and I can get into the desktop from there. No, I don’t know why I have to reboot from LTS to avoid a black screen.
Dang. I admit I don’t know how to fix that as I’m not familiar with that type of issue. Sorry. Hopefully more other people will chime in?
Although I will say, Isn’t kernel 7 still a release candidate still (not the main full release yet??? If it’s only a release candidate, it’s kinda still similar to betaware (although closer to release than pure beta). I would wait a few more days or weeks before installing kernel 7.
To help clarify, could you please do a “uname -a” and “lsb_release -a” to let us know which one is working or not? (I’m confused about which kernel you are using in terms of actual release numbers). Or, alternatively, you could do a screenshot of cachyos-kernel-manager, right?
7.0 is ‘mainline’ rather than rc now.
And for cachy most kernels are now 7.0+ unless LTS or hardened or something like that.
OK, thanks. I guess I’ll step aside. I’m outta my league.
I’m only seeing
cachyos/linux-cachyos-rc (package name) 7.0.rc5-2 (version) release candidate (category)
…on my cachyos-kernel-manager, but I might have accidentally diabled kernel updates on my system. I will let somebody else try and troubleshoot as I guess I’m not able to help.
P.S. - “uname -a” from a commandline would show which precise kernel you are actually running without having to invoke the kernel manager. For example, it might begin with “6.12.10-8-cachyos” or something like that. But if you are relunctant, I understand. “lsb_release -a” doesn’t show much on CachyOS yet.
Will do in a bit. Is there any way to exclude a program from Syu?
Then look again?
But as to the rc kernels - those are effectively defunct right now.
As they have not been updated to 7.1 (The real rc right now) .. so they are actually behind the current linux-cachyos etc.
Yes but if you have anything else like out of tree modules you will need to exclude those too.
If you need to update right now and cannot otherwise get around the issue it would probably be better to simply install/use an LTS kernel.
PS.
For whatever it is worth things seem ok on my v3 machine with 7.0.0-1-cachyos-bore-lto.
PPS.
Due to some of the other threads I might ask if users here experiencing this have virtualbox-host-dkms installed? That seems to be the cause in other cases.
I had VirtualBox when the issue first arose, but it persisted after a full reinstall without VirtualBox, so that’s not it, if that helps.
7.0.0-1 of linux-cachyos is the main kernel I’m trying to run. That one fails. I have LTS and that one works fine. But I do need to know what’s going on with the main kernel.
I apologize for being a sideshow.
My computer CPU is only x86_64_v2, so my CachyOS doesn’t get packages and kernels as fast as the v3/v4 CPU people. That’s why I couldn’t see what you are seeing. Sorry about that. That difference is in the release notes or whatnot, but I didn’t notice until after my full install and config (went well).
I won’t post any more replies in this thread so you guys can maybe solve this. But I’ll keep reading as I’m curious too.
