CachyOS stuck on loop
Whenever I boot up CachyOS, I (sometimes) get stuck on this screen. All I see is a spinning circle. I can’t do anything (CTRL+ALT+FX) or so. Only reboot using CTRL+ALT+DEL
I don’t know why that’s happening. I hope someone can help me.
Hello and welcome,
You can disable the boot splash to at least see whats happening;
And for general system info and the like we could do this:
sudo cachyos-bugreport.sh
Removing the “splash” thingie instantly boots up to KDE. 3 tries, 3 success. Could it be that Playmouth is buggy?
I mean .. I think it is.
Theres lots of anecdotal posts of it not working right and/or breaking boot under different conditions.
It might be fixable if you apply early-KMS or something else.
But to me it is at best an unnecessary process/animation that can only slow down your boot and hide information. When it is working perfectly. So I banish it on my systems.
I disabled it completely in my grub and let’s hope that my issues are now fixed. I mean I wouldn’t be able to see the fancy splash anyway because around that time my other monitor turns on, causing both monitors to refresh
Hey everybody,
i had the same exact issue. And thx for the workaround. After removing splash it is normally booting.
I send out also the bug report. But what I can report is, that the issue appears after setup secure boot. I added the packman system hook, for sbctl auto signing if boot manager or kernel updates were applied. Then booting into system was only possible in really rare moments. So I think this hook and Plymouth in combination results for me into this endless loop.
