Hi, has anyone tried installing Cachy on Asus Zenbook Duo 2026? I am trying to dual boot the Cachy along with Windows 11, but facing a few issues (The Installation was complete though)
- when I boot into Cachy, the main display starts inverted, and I have to manually change the Orientation to Upside Down from the Display Settings.
- Sometimes the OS just freezes and have to hard reboot using the power button
- Second Display is not working at all. This was my second dual boot. First time when I tried, the second display was working, but everytime the OS froze at the login screen so I couldnt even login. So did Dual Boot again and masked the iio-proxy sensor as suggested by Gemini, which stopped the OS to freeze and I could login, but the second display stopped working even though it shows the Display is enabled in the Display Settings. And the OS freezes everytime I try to fix the display.
- Keyboard doesnt work once detached. The keyboard doesnt connect via Bluetooth as seamlessly as it does on Windows.
There are some open source tools I could find on GitHub made for Zenbook Duo, but I have not been able to try those since the OS freezes everytime I try to fix the second display.
Has anyone been able to use Cachy on their Asus Zenbook Duo 2026 seamlessly?
