CachyOS modules/patches/schedulars etc on gentoo
Greetings to all! I am a cachyos user who is creating a gentoo machine in a VM and with this more customised version of gentoo, i plan to replicate my vm on my older computers which are a lot slower than my laptop I am using right now.
I am at the stage of my gentoo installations where I am working with USE Flags and will go onto configuring my kernel next, so I am planning.
On the cachyos github page GitHub - CachyOS/linux-cachyos: Archlinux Kernel based on different schedulers and some other performance improvements., when you scroll down, there is a chapter(?) that has the title of Other GNU/Linux distributions. As I want the performance benefits of cachyos but on a more optimised system that is gentoo which as it is source based, it will be ultra customised to my uses (pun intended) and the hardware, is there a way for me to get the benefits of cachyos on gentoo?
eselect repository add CachyOS-kernels git https://github.com/Szowisz/CachyOS-kernels
emaint sync -r CachyOS-kernels
the above was copied from the cachyos github page. as this is mostly to do with the kernel, i believe that the people here would be able to help me sorta merge the two kernels as in, keep the gentoo kernel but bolt on the benefits of cachyos.
Thanks to all in advance!
