Cachyos + chaotic-aur
Just wanted to understand would you recommend using chaotic-aur with cachyos?
Note: tried searching for answer couldn’t stumble across any
Well, you can use it. But we dont really want to support users, which installs dozens of git packages from there
So, it’s not recommended, but if you’re getting something from the AUR anyways, it can save you time. That being said, make sure the priority is as low as possible, and always ALWAYS prefer things in the CachyOS repos when you have the choice.
I use chaoticaur for some packages.
It saves sometime.
