Can you help to install BlackArch utilities?
Just install it manually on your own
I have trouble with python-boto, aws-extender-cli. Install with ignore this packages?
What issues?
They asked that you help them install it, not be told to install it on their own. If they knew how to install it manually, they would not be asking for help. So maybe it would be more productive if you explained to them how they can do it manually instead.
- download package
- install it with pacman (add repository)
- solve issues
but mixed repositories are a bit complicated, and if you can’t use pacman with full functionality… in short: i expect more trouble, because python is a bitch
@MisterKloun i would ignore this packages, when the program work as you expect.
