Cachy-browser problem
Any idea on solving this apart from turning off hardware acceleration?
❯ cachy-browser
libva error: /usr/lib/dri/nvidia_drv_video.so init failed
[Parent 35702, Compositor] WARNING: Call to mmap failed: Bad file descriptor: file /tmp/pkg/src/firefox-128.0/ipc/chromium/src/base/shared_memory_posix.cc:515
###!!! [Parent][DispatchAsyncMessage] Error: SHMEM_CREATED_MESSAGE Payload error: message could not be deserialized
Crash Annotation GraphicsCriticalError: |[0][GFX1-]: TOpAddBlobImage failed (t=106.226) [GFX1-]: TOpAddBlobImage failed
Crash Annotation GraphicsCriticalError: |[0][GFX1-]: TOpAddBlobImage failed (t=106.226) |[1][GFX1-]: TOpAddBlobImage failed (t=106.226) [GFX1-]: TOpAddBlobImage f
ailed
Crash Annotation GraphicsCriticalError: |[0][GFX1-]: TOpAddBlobImage failed (t=106.226) |[1][GFX1-]: TOpAddBlobImage failed (t=106.226) |[2][GFX1-]: TOpUpdateBlob
Image failed (t=106.226) [GFX1-]: TOpUpdateBlobImage failed
Image failed (t=106.226) |[3][GFX1-]: TOpAddBlobImage failed (t=106.226) [GFX1-]: TOpAddBlobImage failed
Image failed (t=106.226) |[3][GFX1-]: TOpAddBlobImage failed (t=106.226) |[4][GFX1-]: TOpUpdateBlobImage failed (t=106.226) [GFX1-]: TOpUpdateBlobImage failed
Image failed (t=106.226) |[3][GFX1-]: TOpAddBlobImage failed (t=106.226) |[4][GFX1-]: TOpUpdateBlobImage failed (t=106.226) |[5][GFX1-]: TOpUpdateBlobImage failed
Exiting due to channel error.
Crash Annotation GraphicsCriticalError: |[C0][GFX1-]: CompositorBridgeChild receives IPC close with reason=AbnormalShutdown (t=105.191) Exiting due to channel err
or.
fish: Job 1, ‘cachy-browser’ terminated by signal SIGSEGV (Address boundary error)
Which version you are on?
128-0.4 running on cachyos-znver4
Which desktop enviroment/hardware you have?
I can not reproduce this on my machine with Zen4 repos.
  :++===++==================-       :++-           OS: CachyOS Linux x86_64
    :*++====+++++=============-        .==:           Host: MS-7E26 (1.0)
   -*+++=====+***++==========:                        Kernel: Linux 6.10.0-3-cachyos
  =*++++========------------:                         Uptime: 11 hours, 11 mins
 =*+++++=====-                     ...                Packages: 1416 (pacman)
.++++++=-===: .=+++=: Shell: fish 3.7.1
:++++=====-==: -+ Display (LG ULTRAGEAR): 2560x1440 @ 120Hz
+. DE: KDE Plasma 6.1.3
.+==========-. . WM: KWin (Wayland)
:+++++++====- .–==-. WM Theme: Breeze
:++==========. :+++++++: Theme: Breeze (Dark) [Qt], Breeze-Dark [GTK2], Breeze [GTK3]
+ Icons: breeze-dark [Qt], breeze-dark [GTK2/3/4]
.-===========: .++: Font: Noto Sans (10pt) [Qt], Noto Sans (10pt) [GTK2/3/4]
-=======++++:::::::::::::::::::::::::-: .—: Cursor: breeze (24px)
***********=. Terminal: konsole 24.5.2
- CPU: AMD Ryzen 7 7700 (16) @ 5.58 GHz
- GPU 1: AMD Raphael [Integrated]
.===+==================+++++++: GPU 2: NVIDIA GeForce RTX 4070 [Discrete]
.-=======================+++: Memory: 3.85 GiB / 30.54 GiB (13%)
… Swap: 549.75 MiB / 30.54 GiB (2%)
Disk (/): 382.93 GiB / 929.51 GiB (41%) - btrfs
Local IP (wlan0): 192.168.0.117/24
Locale: en_ZA.UTF-8
Does it work fine, if you do MOZ_ENABLE_WAYLAND=0 cachy-browser ?
Edit:
Having equal setup. Just 7950X3D and 4070S
Seems to work, there are characters randomly missing in the displayed URL but everything else is good: e.g. Cachy-browser problem - #5 by Antiram has characters missing but it still works
libEGL warning: egl: failed to create dri2 screen
ATTENTION: default value of option mesa_glthread overridden by environment.
