hello guys
i have this command to type
evdev-joystick -s /dev/input/by-id/usb-Fanatec*-event-joystick
my device id is ; ID 0eb7:0197 Endor AG
i tried to enter the id in the command 0eb7:0197 or 0eb7 and it doesnt work , i haven t created any udev rules for my fanatec wheel yet , i tried to read the udev arch wiki but i cannot understand any of it , how should i type the command with the good " by-id " thing please ? or maybe i should create the rule before typing the command ? how do i create the rule with the good id or "event path device ?
for context , i have installed a fanatec wheel with the hid-fanatecff driver , then i installed joystick using paru -S joystick , now i want to reduce the dead zone of the wheel following these instructions
Large deadzone or chunky input
Check the deadzone/flatness/fuzz settings:
This should output s.t. like ... flatness: 0 (=0.00%), fuzz: 0) for all axis. If this is not the case then check that the udev rule works. Execute
udevadm test /dev/input/by-id/usb-Fanatec*-event-joystick
and see if /etc/udev/rules.d/99-fanatec.rules gets called.
please delete this topic moderators
