Bug: I2C Synaptics Touchpad (SYNA3602) requires pci=nocrs on CachyOS, breaking power management
I am experiencing an issue where my I2C Synaptics Touchpad does not function on the default CachyOS kernel. The device only initializes when I boot with the pci=nocrs kernel parameter.
While pci=nocrs provides a temporary workaround for the touchpad, it negatively impacts power management by preventing the system from reaching deep C-states (specifically C10). Previously, I also tried pci=nocrs irqpoll, which completely broke C-states (C10 = 0).
For comparison, the touchpad works perfectly out-of-the-box on Fedora using their latest kernel, with no special kernel parameters required and deep C-states functioning normally. This suggests a potential kernel configuration or patch difference between the two distributions.
System Information
  • Laptop model: Infinix Y4 Max (YL613 series)
  • CPU: Intel Core i3-1315U
  • GPU: Intel integrated (i915)
  • Distribution: CachyOS (Arch-based)
  • Kernel: linux-cachyos 7.0.11-1
  • Bootloader: Limine
  • Desktop: KDE Plasma (Wayland)
Touchpad Information
  • Device: SYNA3602:00 093A:35ED Touchpad
  • Kernel: /dev/input/event13
  • ID: i2c:093a:35ed
  • Driver: i2c_hid
Behavior Summary
Configuration Touchpad Power Management
Default CachyOS kernel Fails to initialize Normal
pci=nocrs Works C10 not reached
pci=nocrs irqpoll Works C-states broken
Fedora kernel Works (Out-of-the-box) Normal
Attempted Fixes
I have tried passing the following kernel parameters independently, but the touchpad remains non-functional unless pci=nocrs is present:
  • i2c_hid.acpi_irq=1
  • i2c_hid.force_polling=1
Observations & Requests
Because the device uses I2C HID and pci=nocrs acts as a workaround, this points toward an ACPI resource or IRQ routing issue.
Could the team please look into:
  1. Why i2c_hid fails without pci=nocrs on the CachyOS kernel.
  2. Any relevant ACPI resource handling or I2C HID patches that might be present in Fedora but missing in CachyOS.
  3. Whether a device-specific quirk can be added for SYNA3602:00 093A:35ED.
I have logs ready and can provide the output for dmesg | grep -iE "i2c|hid|touch", lspci -vv, or my full kernel cmdline if needed. Thank you for your time and work on the kernel!
logs:
Current Kernel Command Line:
quiet nowatchdog splash rw root=UUID=83494427-7cfa-4c7a-8b92-ba22316d595e pci=nocrs irqpoll
https://paste.cachyos.org/p/bb29d4f.log
Translated using ai
