Hi.
I have an issue with the linux-cachyos-bore kernel (same happens with linux-cachyos-bore-lto).
When the system is under moderate or high load (gaming, shader compilation, heavy CPU/GPU usage, etc.), the secondary monitor starts showing visual glitches/artifacts/flickering.
Important details:
The issue only happens on BORE kernels.
Standard CachyOS kernel work fine.
bore-lto has the exact same problem.
The glitches appear specifically on the second monitor.
GPU: GTX 1650
CPU: i3-10100F
NVIDIA driver version: 595.71.05
The issue is reproducible and disappears after switching to another kernel variant.
I will attach a video showing the issue.
Could this be related to scheduling changes in BORE or some interaction with NVIDIA drivers/multi-monitor setups?
