Hi all,
Currently running into this same issue.
I am on kernel 6.19.12-1-cachyos-hardened. I booted into bleeding edge 6.19.12-1-cachyos and it showed as connected briefly but then failed. LTS has the same symptom as the hardened kernel, never shows as connected using the GUI, it just fails. I have updated to bluez-5.86-4.1 as well as upgrading the entire system.
Error:
Failed to pair: org.bluez.Error.ConnectionAttemptFailed
Logs:
sudo cachyos-bugreport.sh
You have a bluetooth USB dongle, don’t you?
What’s the make and model or is it some generic device?
Looks like this could be an issue with bluez and bluetooth trying to negotiate things. Often times these USB bluetooth dongles have issues with powersaver or may not have firmware drivers available.
try fully booting the system and logging in as your user, and then plugging back in the USB bluetooth dongle.
What device are you trying to connect via bluetooth?
I am trying to connect Audioengine HD3 speakers. I have multiple dongles which are a mouse, keyboard and headphones.
Upgrading to 7.0.0-1 did not resolve the issue.
Thanks for the heads about this repository!
As stated in @KnB9376 ‘s response, in the Bazzite repo, a power drain works.
This is all bluez or bluetooth package issues, or MSI mobo issues. If that isn’t already known.
My guy! Will take a peep when today’s dumpster stops burning
