Hi
I updated my system this morning which included kernel 6.11.4-2-cachyos
and since then I have not been able to connect any previously paired and working bluetooth devices to my computer.
I saw a report on the arch forums about a similar recent issue and downgrading kernel helped them. Sure enough, downgrading to 6.11.3-3-cachyos
works and all devices connect straight away.
Is this a known issue? Anything I can do for now besides sticking with the older kernel?
I can’t be sure if the issue is present in earlier versions of 6.11.4
. I only have the problem version cached to test. If there is a link to download older packages I will happily test.
Thank you for your time and effort. CachyOS has been an amazing experience for the last few months!
Cheers
