This Bluetooth bug has been around for a few months now. I’ve found a temporary solution using “bluman” that works fine. A tip for the developers: maybe replace the default CachyOS Bluetooth manager with “bluman.”
I haven’t found a permanent fix, but a more convenient workaround is to disable the Bluetooth service on startup using KDE settings, then enable it manually afterward….. or just use Blueman as mentioned above.
The issue appears to be an issue with the KDE connect app (which installs by default with KDE Plasma) and an interaction with recent versions of bluez. I spent a few days troubleshooting, and found that the two solutions appear to be downgrading bluez to 5.82 or earlier (I tested 5.80) or uninstalling KDE connect.
Same issue on the latest CachyOS on the Lenovo Yoga with intel 226v.
modules or kernel does not matter.
This is what helped me:
KDE Connect Bluetooth Interference Fix
Symptom
Intermittent Bluetooth connection issues where devices (especially headphones) constantly connect and disconnect. This behavior often appears randomly after system reboots and is independent of the kernel version.
Probable Cause
A resource conflict occurs between the system Bluetooth manager (BlueZ) and the KDE Connect Bluetooth backend. KDE Connect attempts to hijack the Bluetooth adapter to scan for devices, causing instability in audio streams. Furthermore, a bug in KDE Connect prevents the “Disable Bluetooth” setting from persisting because it incorrectly identifies the backend provider name in the config file.
Solution
Manually force-disable the Bluetooth backend in the KDE Connect configuration by using the correct internal identifier: AsyncLinkProvider.
Step-by-Step Instructions
1. Prepare the Configuration
First, ensure the configuration directory exists and open the file. We will use nano, but you can use any text editor.
Bash
nano ~/.config/kdeconnect/config
2. Edit the [General] Section
Look for the [General] heading.
If you don’t see[General]: Add it at the top.
Ifdisabled_providersexists: Ensure AsyncLinkProvider is added to the list.
If it doesn’t exist: Add the line below the heading.
Your file should look like this:
Plaintext
[General]
disabled_providers=AsyncLinkProvider
(Note: If you have multiple providers to disable, separate them with a semicolon, e.g.,ProviderA;AsyncLinkProvider*)*
3. Save and Exit
Press Ctrl + O, then Enter to save.
Press Ctrl + X to exit.
4. Restart the Service
Apply the changes immediately by restarting the KDE Connect daemon with this command:
