Hey yall im back with another problem lol. Maybe its me? Maybe its the Install who knows.
So my issue is since install which is about… 1 and 1/2 week ago (fresh install) I had a problem where the bluetooth was like auto-disabled and on every reboot i have to sysctl bluetooth enable, now even then I have gone the through the GUI and enabled the box’s where they say “enable bluetooth”. So what im asking is what command or fix do I need to do to keep it enabled. If anyone has any questions feel free to ask
My Bluetooth does not work anymore too.
I switched the Kernel from RC to Normal and it is still not working.
I tried to reinstall bluez, " sudo systemctl enable --now bluetooth.service" doesn’t do anything. Tried out blueman. Before it was working. After installing RC-7-5 it seems to break or new Kernel. (Not sure).
Check with dmesg if its the same adapter. There is a firmware attached, which can be copied to the firmware folder, its located on archlinux at /usr/lib/firmware.
I just started with CachyOS. I mean I saw “MT7961” with dmesg. It looks like that I now have messed up something with USB. After reboot the mouse needs 5 Minutes to come back. I rolled back a “CloneZilla Image”. Maybe I can downgrade to 6.8.
Uffff I think the downgrade will not work with the Kernel Manager.
Was hopping it is easy to get my Bluetooth to work again.
I use a ASUS B650E-F Gaming Motherboard.
Fehler: Vorgang konnte nicht vorbereitet werden (Kann Abhängigkeiten nicht erfüllen)
:: Entfernen von linux-cachyos-hardened verletzt Abhängigkeit »linux-cachyos-hardened=6.8.9-4«, benötigt von linux-cachyos-hardened-nvidia
:: Entfernen von linux-cachyos verletzt Abhängigkeit »linux-cachyos=6.9.1-2«, benötigt von linux-cachyos-nvidia
:: Entfernen von linux-cachyos-rc verletzt Abhängigkeit »linux-cachyos-rc=6.9.rc7-5«, benötigt von linux-cachyos-rc-nvidia
:: Entfernen von linux-cachyos verletzt Abhängigkeit »UKSMD-BUILTIN«, benötigt von uksmd-git
Press enter to exit
Now it is even more worst. Today the issue come back no Bluetooth at all plus after I see the Desktop I have to wait 3 to 4 minutes until my Keyboard and Mouse work. I see that then my audio devices getting re detected again.
What I’am doing wrong. I only copied yesterday those “.bin Firmware” to lib/firmware/mediatek.
Is there maybe a extra step? Sorry I’am a aboslut Linux beginner. Just wondering because yesterday everyting was fine. I go crazy
My USB has “long wait time issues”. I will restore my working “CachyOS” with my CloneZilla Image because I don’t know how to fix that. Then I will downgrade the Kernel, “signing secure boot” and reinstall my programs. I messed up my System 7 times but I like CachyOS so much. Big thanks.
The Bluetooth under LTS does work.
In the Kernel Manager → “is Configuration / Konfigurieren Sie” what is this?
Are those Patches good for Gaming/ CPU Performance / Optimization?
It looks like that it does auto Upgrade to 6.9.1-2. Can I apply those Patches somehow under LTS?
So far it looks good when I copy the Firmware to /usr/lib/firmware/mediatek then my Bluetooth also “survive” the restart.
Ahhh okay and in my case plus Nvidia ? This linux-cachyos-lts-nvidia necessary? I mean last time without nvidia it become unbootable or should I always do “sudo mkinitcpio -P” ?
I think my Problem was that with “rEFInd” there was only one Kernel (the default) to select.
The other where not shown. I know with GRUB it looks a bit different. Maybe there is a way to get multiple selections with rEFInd.
But for now everything is fine. Feels very smooth. Hunt Showdown runs amazing. CachyOS best!
