My Blue Yeti microphone requires to be replugged after every restart/suspend to function. It is always recognized by the system, but no input detected until I replug it. I have had this issues on other Linux Distros aswell, but I hope that over here somebody may have a solution.
The output of dmesg after suspending (with the microphone **not working)
[ 2614.089716] Disabling lock debugging due to kernel taint
[ 2614.089719] usbcore: deregistering interface driver snd-usb-audio
[ 2614.188509] usb 1-4: 1:1: cannot get freq at ep 0x81
[ 2614.190614] usb 1-4: 2:1: cannot get freq at ep 0x1
[ 2614.249776] usb 1-4: 1:1: cannot get freq at ep 0x81
[ 2614.552869] usbcore: registered new interface driver snd-usb-audio
[ 2633.075319] usbcore: deregistering interface driver snd-usb-audio
[ 2633.186775] usb 1-4: 1:1: cannot get freq at ep 0x81
[ 2633.188858] usb 1-4: 2:1: cannot get freq at ep 0x1
[ 2633.298505] usb 1-4: 1:1: cannot get freq at ep 0x81
[ 2633.543446] usbcore: registered new interface driver snd-usb-audio
[ 2886.543397] usb 1-7: USB disconnect, device number 8
[ 2886.824175] usb 1-7: new high-speed USB device number 9 using xhci_hcd
[ 2887.086739] usb 1-7: New USB device found, idVendor=046d, idProduct=0ab7, bcdDevice= 0.19
[ 2887.086743] usb 1-7: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 2887.086744] usb 1-7: Product: Blue Microphones
[ 2887.086745] usb 1-7: Manufacturer: Generic
[ 2887.086745] usb 1-7: SerialNumber: 2033BAB02YC8
[ 2887.235163] usb 1-7: 2:2: cannot set freq 48000 to ep 0x4
[ 2887.255165] usb 1-7: 19:0: failed to get current value for ch 0 (-22)
[ 2887.295162] usb 1-7: 19:0: cannot get min/max values for control 2 (id 19)
[ 2887.315163] usb 1-7: 25:0: failed to get current value for ch 0 (-22)
[ 2887.375160] usb 1-7: 35:0: failed to get current value for ch 0 (-22)
[ 2887.415161] usb 1-7: 35:0: cannot get min/max values for control 2 (id 35)
[ 2887.435161] usb 1-7: 22:0: failed to get current value for ch 0 (-22)
[ 2887.475161] usb 1-7: 22:0: cannot get min/max values for control 2 (id 22)
[ 2887.477352] usbhid 1-7:1.3: can’t add hid device: -71
[ 2887.477367] usbhid 1-7:1.3: probe with driver usbhid failed with error -71
[ 2887.477424] usb 1-7: USB disconnect, device number 9
[ 2890.001149] usb 1-7: new high-speed USB device number 10 using xhci_hcd
[ 2891.095195] usb 1-7: device descriptor read/64, error -71
Specs
System Details Report
Report details
Date generated: 2025-10-19 10:15:44
Hardware Information:
Hardware Model: Micro-Star International Co., Ltd. MEG Z490 Trident X MS-B926
If the microphone is not detected at the kernel level, it may be due to a missing firmware for a Renesas USB controller, which some Blue Yeti models use. In such cases, installing the upd72020x-fw package from the Arch User Repository (AUR) can resolve the issue.
This firmware is necessary for the USB controller to function properly.
For users experiencing the microphone not working until manually unplugged and replugged, a simple fix involves reloading the snd_usb_audio kernel module:
Thank you for your time and help! Unfortunately both, the firmware and the commands, dont fix the issue. I have read about sudo rmmod snd_usb_audio -f and sudo modprobe snd_usb_audio in the Arch forum and generally it seems to do nothing for many people, which I find strange, since it is essentially the same as manually replugging from what I can understand.
Unfortunately I cannot see something special in your systems details.
There is only one thing you can try in addition. Restart COS and choose the LTS Kernel in the advanced Menu of CachyOS.
If the problem still presists, somebody else may handle your case with better care.
Alright, I already installed the firmware after your first response. Sorry, should’ve stated it more clearly.
I tried the LTS Kernel, but it still doesn’t work, unfortunately. Maybe an update of the firmware will fix it, since the version now available in the AUR dates to 2025-05-25, which of course is a while back. In the meantime I will have to continue to replug.
But still, thank you so much for your time and effort! It’s really appreciated. People like you help to make Linux more accessible to new users.
So it turns out to be the usual logitech firmware thing. One can try Blue Sherpa or G Hub for updates.
You are lucky, a logitech mouse would have lead into serious system errors making any linux gui unusable.
For early adoptors: There is no chance of getting a new firmware. So heading for a new mic would be the easiest solution.
