Can you use auto-cpufreq and bpftune together ? Or is that rather a bad idea ?
Do any of you use auto-cpufreq at all ?
I do not suggest auto-cpufreq at all, only if you have some really specific needs.
power-profiles-daemon doing a good enough job.
@ptr1337
OK, Is it possible to use Bpftune together with tuneD ? Or will there be conflicts ?
I have had good experiences with tuneD under Debian, hence the question.
