A Schiit Modi (alsa_output.usb-Schiit_Audio_Schiit_Modi_3-00.iec958-stereo), plays audio crackles when audio is playing. This does not occur on Linux Mint.
Per ArchWiki and various posts, I’ve tried:
Every combination of PipeWire default.clock.rate and default.min-quantum (.conf in ~/.config/pipewire/pipewire.conf.d)
Every combination of WirePlumber audio.format, audio.rate, and api.alsa.period-size (.conf in ~/.config/wireplumber/wireplumber.conf.d)
Every quantum set via CLI: pw-metadata -n settings 0 clock.force-quantum n
Other ideas that have worked for others, but I haven’t tried, include:
Changing PCIe from Gen4 to Gen3 in the BIOS
Rerouting cables in the chassis
Using a USB expansion card
Plugging the computer and audio equipment into an AC outlet filter also didn’t help this issue.
One thing I hadn’t mentioned is swapping the USB cable. (IIRC, this is the first thing I tried and it didn’t help, but that was months ago and I’ve searched and tried much since.) Regardless, I tried swapping the USB cable again, and voila! The problem seems sovled!
FWIW, the replacement cable is thicker than the old, stock cable, which had been working flawlessly for years with other computers and operating systems.
Therefore, even if CachyOS contributes to this issue, my solution is not CachyOS-specific.
Since I didn’t see anyone mention my solution, I’ll add it.
Had a Schiit Modi 3 that had a random crackle. Cable wasn’t the issue, but the USB port was. USB 2 should be enough, but the crackle went away completely when I swapped the cable from one of the USB 2 ports on my motherboard to one of the USB 3 ports on my motherboard.
