I’ve used the script to switch my base Arch install over to the Cachy repos.
After rebooting I also installed linux-cachyos but noticed that DKMS failed to build the modules for the nvidia driver (and also for virtualbox).
Checking the logs clang & lld were missing from my Arch install, after adding those and attempting to re-install the kernel, the DKMS builds appeared to complete but there were many warnings from the nvidia driver:
==> dkms install --no-depmod nvidia/565.57.01 -k 6.11.5-3-cachyos
strip: /var/lib/dkms/nvidia/565.57.01/build/kernel-open/nvidia-modeset.ko: invalid entry (0) in group [8]
strip: /var/lib/dkms/nvidia/565.57.01/build/kernel-open/nvidia-modeset.ko: invalid entry (0) in group [97]
strip: /var/lib/dkms/nvidia/565.57.01/build/kernel-open/nvidia-modeset.ko: invalid entry (0) in group [98]
strip: /var/lib/dkms/nvidia/565.57.01/build/kernel-open/nvidia-modeset.ko: invalid entry (0) in group [144]
strip: /var/lib/dkms/nvidia/565.57.01/build/kernel-open/nvidia-modeset.ko: invalid entry (0) in group [145]
strip: BFD (GNU Binutils) 2.43.0 assertion fail /usr/src/debug/binutils/binutils-gdb/bfd/elf.c:3944
Upon booting with the cachy kernel sddm does not appear (it does appear with the arch kernel that is also installed). I’m assuming the module isn’t built correctly. Any ideas?
