April 22 26 update I lose audio on laptop
after updating I lose audio on laptop. Onboard and Jacked speakers fail to work. I don’t know what is causing it and my only fix so far was rolling back a snapshot.
Well, if you rolled back a snapshot to when it previously worked, I would think it’s likely it’s a hardware issue.
You can boot off a non-current ISO to test functionality.
usas dualboot?
Tested on the newest iso version on USB, no sound, but works on an older ISO.
Yes, I dual boot.
