If you never changed something after the installation on your NVIDIA Drivers then you do not have to do anything!!
To facilitate the introduction of the NVIDIA 590 driver series, CachyOS is updating the structure of its NVIDIA driver packages. The current “NVIDIA Closed” driver is being replaced by nvidia-580xx-utils to serve as the stable foundation while the 590 branch is introduced.
Instructions by GPU Architecture
For Pascal and Older Architectures
If you are using a GPU based on the Pascal architecture (GTX 10-series) or older, no manual intervention is required.
- The package manager will handle the dependency change automatically.
- Simply perform a standard system update:
sudo pacman -Syu
For Turing and Newer Architectures
If you are using a Turing card (RTX 20-series and 1650 series) or newer, please verify your installed driver packages.
If you previously manually switched to linux-cachyos-nvidia: You generally need to migrate back to the stable branch to stay on the 590 series. The linux-cachyos-nvidia-open package is expected to follow the bleeding-edge 590 branch.
How to migrate: Run the following command to install the kernel, headers, and the stable module driver:
sudo pacman -S linux-cachyos-nvidia-open linux-cachyos-lts-nvidia-open nvidia-utils opencl-nvidia lib32-nvidia-utils lib32-opencl-nvidia nvidia-settings
Note: Ensure you install the module matching your specific kernel (e.g., if you use
linux-cachyos-bore, installlinux-cachyos-bore-nvidia-open).
The 590 Driver will be pushed in 2-3 days.
Thank you for flying with CachyOS! ![]()
