Ananicy-cpp.service isn't starting propperly and needs to be restarted manually for its cgroup settings to work
Hi, everyone
On my system, ananicy-cpp.service isn’t working as intended or more correctly it starts before the cgroups controller is available.
 ╰─λ systemctl status ananicy-cpp.service
● ananicy-cpp.service - Ananicy-Cpp - ANother Auto NICe daemon in C++
     Loaded: loaded (/usr/lib/systemd/system/ananicy-cpp.service; enabled; preset: disabled)
     Active: active (running) since Fri 2025-09-12 12:34:44 +08; 1 day 3h ago
 Invocation: db0ecf18c9204e65884aa5a8939f59cc
   Main PID: 684 (ananicy-cpp)
      Tasks: 4 (limit: 17698)
     Memory: 8.7M (high: 16M, max: 64M, available: 7.2M, peak: 11.9M)
        CPU: 21.634s
     CGroup: /system.slice/ananicy-cpp.service
             └─684 /usr/bin/ananicy-cpp start
Sep 12 12:34:44 wisejackal-laptop ananicy-cpp[684]: Ananicy Cpp
Sep 12 12:34:44 wisejackal-laptop ananicy-cpp[684]: [2025-09-12 12:34:44.397] [info] Starting Ananicy
Sep 12 12:34:44 wisejackal-laptop ananicy-cpp[684]: [2025-09-12 12:34:44.400] [warning] cgroup2 at /sys/fs/cgroup/ananicy_test_cgro>
Sep 12 12:34:44 wisejackal-laptop ananicy-cpp[684]: [2025-09-12 12:34:44.400] [info] Creating Cgroups...
Sep 12 12:34:44 wisejackal-laptop ananicy-cpp[684]: [2025-09-12 12:34:44.400] [warning] Cgroups are not available on this platform >
Sep 12 12:34:44 wisejackal-laptop ananicy-cpp[684]: [2025-09-12 12:34:44.400] [info] Finished creating Cgroups...
Sep 12 12:34:44 wisejackal-laptop ananicy-cpp[684]: [2025-09-12 12:34:44.402] [info] Doing a full scan
Sep 12 12:34:44 wisejackal-laptop ananicy-cpp[684]: [2025-09-12 12:34:44.413] [info] Worker initialized with 1383 rules
lines 1-21/21 (END)
After a manual systemctl restart ananicy-cpp.service
lines 1--1...skipping...
     Active: active (running) since Sat 2025-09-13 15:46:26 +08; 26s ago
 Invocation: 46daba68c6bd4af6974489f7bc81c0eb
   Main PID: 141062 (ananicy-cpp)
     Memory: 7.6M (high: 16M, max: 64M, available: 8.3M, peak: 7.8M)
        CPU: 87ms
             └─141062 /usr/bin/ananicy-cpp start
Sep 13 15:46:26 wisejackal-laptop ananicy-cpp[141062]: [2025-09-13 15:46:26.317] [info] Config apply_ionice: true
Sep 13 15:46:26 wisejackal-laptop ananicy-cpp[141062]: [2025-09-13 15:46:26.317] [info] Config cgroup_load: true
Sep 13 15:46:26 wisejackal-laptop ananicy-cpp[141062]: [2025-09-13 15:46:26.317] [info] Config apply_sched: true
Sep 13 15:46:26 wisejackal-laptop ananicy-cpp[141062]: [2025-09-13 15:46:26.317] [info] Config apply_nice: true
Sep 13 15:46:26 wisejackal-laptop ananicy-cpp[141062]: Ananicy Cpp
Sep 13 15:46:26 wisejackal-laptop ananicy-cpp[141062]: [2025-09-13 15:46:26.329] [info] Starting Ananicy
Sep 13 15:46:26 wisejackal-laptop ananicy-cpp[141062]: [2025-09-13 15:46:26.330] [info] Creating Cgroups...
Sep 13 15:46:26 wisejackal-laptop ananicy-cpp[141062]: [2025-09-13 15:46:26.331] [info] Finished creating Cgroups...
Sep 13 15:46:26 wisejackal-laptop ananicy-cpp[141062]: [2025-09-13 15:46:26.332] [info] Doing a full scan
Sep 13 15:46:26 wisejackal-laptop ananicy-cpp[141062]: [2025-09-13 15:46:26.342] [info] Worker initialized with 1383 rules
Where is the correct place to report this, or what are the further steps from here?
I opened this issue, but that’s kinda the wrong place:
in time started:
     Loaded: loaded (/etc/systemd/system/ananicy-cpp.service; enabled; preset: disabled)
     Active: active (running) since Sat 2025-09-13 12:34:55 CEST; 2h 15min ago
 Invocation: ff5f1cb0343b4352b5f3982ae2aca3f4
   Main PID: 410 (ananicy-cpp)
      Tasks: 4 (limit: 18554)
     Memory: 15.1M (high: 16M, max: 64M, available: 896K, peak: 18.5M, swap: 728K, swap peak: 1.3M, zswap: 4.6K)
        CPU: 22.702s
             └─410 /usr/bin/ananicy-cpp start
Sep 13 12:35:03 frija ananicy-cpp[410]: [2025-09-13 12:35:03.587] [info] Config apply_ionice: true
Sep 13 12:35:03 frija ananicy-cpp[410]: [2025-09-13 12:35:03.587] [info] Config cgroup_load: true
Sep 13 12:35:03 frija ananicy-cpp[410]: [2025-09-13 12:35:03.587] [info] Config apply_sched: true
Sep 13 12:35:03 frija ananicy-cpp[410]: [2025-09-13 12:35:03.587] [info] Config apply_nice: true
Sep 13 12:35:03 frija ananicy-cpp[410]: Ananicy Cpp
Sep 13 12:35:09 frija ananicy-cpp[410]: [2025-09-13 12:35:09.003] [info] Starting Ananicy
Sep 13 12:35:09 frija ananicy-cpp[410]: [2025-09-13 12:35:09.005] [info] Creating Cgroups...
Sep 13 12:35:09 frija ananicy-cpp[410]: [2025-09-13 12:35:09.005] [info] Finished creating Cgroups...
Sep 13 12:35:09 frija ananicy-cpp[410]: [2025-09-13 12:35:09.006] [info] Doing a full scan
Sep 13 12:35:09 frija ananicy-cpp[410]: [2025-09-13 12:35:09.011] [info] Worker initialized with 1383 rules
…maybe it depends on your system?
Probably, but given that I didn’t do anything to my system that would explain why mine behaves differently …
If you have any troubleshooting ideas tho, I’d love to get it to work as intend.
But nonetheless, it seems like something somewhere should check that cgroups are available before ananicy-ccp tries to start or otherwise catch that it didn’t start properly and try to restart it or something.
you can work around and start ananicy later with a path OR timer
sudo nano /etc/systemd/system/ananicy-cpp.timer
[Unit]Description=starts ananicy-cpp --auto-tune sec 20 after boot
[Timer]OnBootSec=20sec
[Install]WantedBy=timers.target
disable the service and enable the timer if you want a try
btw do you want to use cgroups? if not, you can ignore these errors :slight_smile:
edit
sudo nano /etc/systemd/system/ananicy-cpp.path
[Unit]Description=started ananicy-cppPartOf=ananicy-cpp.service
[Path]PathExists=/sys/fs/cgroup/
[Install]WantedBy=multi-user.target
HI!
Same issue here : using a systemd path as a workaround also fails, and the service is waiting a lot to start :
systemd-analyze blame
8.898s ananicy-cpp.service
Here is the output for the *.path :
systemctl status ananicy-cpp.path
× ananicy-cpp.path - Start ananicy-cpp when cgroups v2 is available
Loaded: loaded (/etc/systemd/system/ananicy-cpp.path; enabled; preset: disabled)
Active: failed (Result: resources) since Mon 2025-09-15 14:26:32 CEST; 49s ago
Duration: 8.926s
Invocation: 46d9bce40b604aa1bea093d5ffa6792d
Triggers: ● ananicy-cpp.service
sept. 15 14:26:23 cachyos-ogu systemd[1]: ananicy-cpp.path: Deactivated suc…lly.
sept. 15 14:26:23 cachyos-ogu systemd[1]: Stopped Start ananicy-cpp when cg…ble.
sept. 15 14:26:23 cachyos-ogu systemd[1]: Stopping Start ananicy-cpp when c…e…
sept. 15 14:26:23 cachyos-ogu systemd[1]: Started Start ananicy-cpp when cg…ble.
sept. 15 14:26:32 cachyos-ogu systemd[1]: ananicy-cpp.path: Failed to queue…ked.
sept. 15 14:26:32 cachyos-ogu systemd[1]: ananicy-cpp.path: Failed with res…es’.
Hint: Some lines were ellipsized, use -l to show in full.
journald is talking about cgroups issues / bpf troubles /segmentation faults
[warning] Cgroups are not available on this platform (or are not enabled)
[warning] cgroup2 at /sys/fs/cgroup/ananicy_test_cgroup2 doesn’t have a cpu controller available, skipping
failed to attach BPF programs
Main process exited, code=dumped, status=11/SEGV
However cgroups seem to work fine:
cat /sys/fs/cgroup/cgroup.controllers
cpuset cpu io memory hugetlb pids rdma misc dmem
mount | grep cgroup
cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime)
none on /run/bpftune/cgroupv2 type cgroup2 (rw,relatime)
So i tried to disable cgroups in the ananicy.conf file with apply_cgroup=false, but that didn’t help.
With these errors, ananicy-cpp does not seems to ionice at all.
Moreover i cannot uninstall it because of cachyos-settings depends on it. I had to delete *.path and then mask services.
I guess we shall wait for an update!
Thanks in advance!
Greetings from France
ogu
Hi, after a bunch of troubleshooting and trying to squeeze useful suggestions out of LLM’s I found the following solution:
sytemd drop-in file: for ananicy-cpp
## Fix ananicy-cpp not starting corectly
## specifically complaining about Cgroups not being available or disabled
[Service]
Delegate=yes
## ​Delegate=yes tells systemd to delegate management of the cgroup subtree to the service.
## This allows ananicy-cpp to create, modify, and manage its own cgroups for the processes it handles,
## without conflicting with systemd’s overall cgroup management.
Systemd override files are best created with sudo systemctl edit ananicy-cpp.service
This will create ‘/etc/systemd/system/ananicy-cpp.service.d/override.conf’
I like to rename it to tell me what it does, so if I ls the folder I already know what is going on, and it allows to easily have a file for each different reason I had to edit something.
Which also means it easy to delete again instead of finding what I edited in a convoluted file.
sudo mv /etc/systemd/system/ananicy-cpp.service.d/override.conf /etc/systemd/system/ananicy-cpp.service.d/override-fix_cgroup_not_available_by_adding_delegate-yes.conf
Do you all think this is a good solution?
Should I try and upstream it?
I don’t fully understand the impacts of Delegate=yes and the ramifications/the impact on ananicy-cpp and the whole system.
Hello @wisejackal and thanks for this workaround. Unfortunately, even with this override, ananicy-cpp systelmd service still fail at boot. Can you please add here the output of systemctl status ananicy-cpp.service, to compare with mine
Mine is just happy, what does yours say?
Anything in the journal?
Straight after a reboot …
systemctl status ananicy-cpp.service:
    Drop-In: /etc/systemd/system/ananicy-cpp.service.d
             └─override-fix_cgroup_not_available_by_adding_delegate-yes.conf
     Active: active (running) since Wed 2025-09-17 03:01:16 +08; 7min ago
 Invocation: 44ef8f47ee83439584f8e692c4bec8eb
   Main PID: 721 (ananicy-cpp)
     Memory: 11.3M (high: 16M, max: 64M, available: 4.6M, peak: 11.8M)
        CPU: 4.032s
             └─721 /usr/bin/ananicy-cpp start
Sep 17 03:01:16 wisejackal-laptop ananicy-cpp[721]: [2025-09-17 03:01:16.424] [info] Config apply_ionice: true
Sep 17 03:01:16 wisejackal-laptop ananicy-cpp[721]: [2025-09-17 03:01:16.424] [info] Config cgroup_load: true
Sep 17 03:01:16 wisejackal-laptop ananicy-cpp[721]: [2025-09-17 03:01:16.424] [info] Config apply_sched: true
Sep 17 03:01:16 wisejackal-laptop ananicy-cpp[721]: [2025-09-17 03:01:16.424] [info] Config apply_nice: true
Sep 17 03:01:16 wisejackal-laptop ananicy-cpp[721]: Ananicy Cpp
Sep 17 03:01:16 wisejackal-laptop ananicy-cpp[721]: [2025-09-17 03:01:16.440] [info] Starting Ananicy
Sep 17 03:01:16 wisejackal-laptop ananicy-cpp[721]: [2025-09-17 03:01:16.447] [info] Creating Cgroups...
Sep 17 03:01:16 wisejackal-laptop ananicy-cpp[721]: [2025-09-17 03:01:16.448] [info] Finished creating Cgroups...
Sep 17 03:01:16 wisejackal-laptop ananicy-cpp[721]: [2025-09-17 03:01:16.450] [info] Doing a full scan
Sep 17 03:01:16 wisejackal-laptop ananicy-cpp[721]: [2025-09-17 03:01:16.460] [info] Worker initialized with 1383 rules
systemctl cat ananicy-cpp.service:
# /usr/lib/systemd/system/ananicy-cpp.service
[Unit]
Description=Ananicy-Cpp - ANother Auto NICe daemon in C++
After=local-fs.target
StartLimitIntervalSec=0
StartLimitBurst=10
[Service]
Type=simple
ExecStart=/usr/bin/ananicy-cpp start
ExecReload=/usr/bin/ananicy-cpp --reload
Nice=-5
SuccessExitStatus=143
OOMScoreAdjust=-999
Restart=always
RestartSec=10
CPUAccounting=true
MemoryHigh=16M
MemoryMax=64M
# Hardening
ProtectSystem=true
ProtectHome=true
PrivateTmp=yes
PrivateDevices=true
ProtectClock=true
ProtectKernelLogs=true
ProtectKernelModules=true
ProtectKernelTunables=true
CapabilityBoundingSet=~CAP_SYS_PTRACE CAP_CHOWN CAP_FSETID CAP_SETFCAP CAP_SETUID CAP_SETGID CAP_SETPCAP
ProcSubset=pid
RestrictAddressFamilies=AF_UNIX AF_NETLINK
NoNewPrivileges=true
lines 1-34...skipping...
[Unit]
StartLimitBurst=10
[Service]
Type=simple
Nice=-5
OOMScoreAdjust=-999
Restart=always
RestartSec=10
CPUAccounting=true
MemoryHigh=16M
MemoryMax=64M
# Hardening
ProtectSystem=true
ProtectHome=true
PrivateTmp=yes
PrivateDevices=true
ProtectClock=true
ProcSubset=pid
RestrictSUIDSGID=true
RestrictNamespaces=cgroup
ProtectHostname=true
LockPersonality=true
MemoryDenyWriteExecute=true
# Filter system calls to those absolutely requrired for correct functioning.
#SystemCallErrorNumber=EPERM
#SystemCallFilter=@system-service
#SystemCallFilter=~@debug @module @mount @reboot @swap @clock @obsolete @cpu-emulation
# Required to see other processes
PrivateUsers=false
ProtectProc=default
# Required for the process-listener socket to work
PrivateNetwork=false
# Required for control groups (obviously)
ProtectControlGroups=false
# Required for future use.
RestrictRealtime=false
[Install]
WantedBy=local-fs.target
# /etc/systemd/system/ananicy-cpp.service.d/override-fix_cgroup_not_available_by_adding_delegate-yes.conf
[Service]
Delegate=yes
lines 27-74/74 (END)
Thanks a lot!
Here is mine: ExecStart fails ( Process: 1945 ExecStart=/usr/bin/ananicy-cpp start (code=exited, status=1/FAILURE) Main PID: 1945 (code=exited, status=1/FAILURE) and i do not manage to understand why?
❯ systemctl status ananicy-cpp.service
     Active: activating (auto-restart) (Result: exit-code) since Wed 2025-09-17 16:38:33 CEST; 3s ago
 Invocation: cfa7acbef4e64fd3a35e235b4b167626
   Mem peak: 2.2M
        CPU: 20ms
❯ systemctl cat ananicy-cpp.service
[Unit]
StartLimitBurst=10
[Service]
Type=simple
Nice=-5
OOMScoreAdjust=-999
Restart=always
RestartSec=10
CPUAccounting=true
MemoryHigh=16M
MemoryMax=64M
# Hardening
ProtectSystem=true
ProtectHome=true
PrivateTmp=yes
PrivateDevices=true
ProtectClock=true
ProcSubset=pid
PrivateUsers=false
ProtectProc=default
[Install]
[Service]
Type=simple
Hey @Ugo,
Check your /etc/systemd/system/ananicy-cpp.service.d/override-fix_cgroup_not_available_by_adding_delegate-yes.conf
It looks like the content is wrong.
It should be:
Hi @wisejackal, i made an error copying the wrong output in the topic…
But the fail is still the same when override is good:
[Install]WantedBy=local-fs.target
specifically it complaining about Cgroups not being available or disabled
[Service]Delegate=yes
Hey Ugo,
Sorry for the super late reply, I’m currently backpacking and didn’t spend much time on my laptop …
To me it looks like you are missing the # sign to make coments comments.
And gennerally your output of cat ananicy-cpp.service seems to be missing the whole contet of the main file, the drop in file is amending.
